05-20-2015 05:12 AM - edited 07-05-2021 03:15 AM
Hello all,
Heard that Cisco has announced the end of life for 1262 series Access points. Can anyone suggest the best replacement for this series of Access Points..
05-20-2015 05:33 AM
HI Rikshit,
Go for AIR-CAP 2602 model.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1260-series/end_of_life_notice_c51-727739.pdf
Don't forget to rate helpful posts
05-20-2015 07:23 AM
Thanks Sandeep
05-20-2015 07:53 AM
Hello Rikshit.
Here is the replacement Product ids and its description for 1262 series
05-20-2015 08:05 AM
Hey Rikshit,
you might as well consider 2700 series with build in 802.11ac capability which is an enhancement of 2600 series, 2700 is also 3X4 with 3 Spatial stream.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2700-series-access-point/datasheet-c78-730593.html
feel free to rate this post if it helps!
05-21-2015 05:36 AM
05-21-2015 02:30 PM
Replacement for 1260 series Access Point is Cisco Aironet 2600 Series,
You can find more information about 2600 Series in the below link :
http://www.cisco.com/c/en/us/products/wireless/aironet-2600-series/index.html
Customers may be able to continue to purchase the Cisco Aironet 1260 Series through the Cisco Certified Refurbished Equipment program. Refurbished units may be available in limited supply for sale in certain countries on a first-come, first-served basis until the Last Date of Support has been reached. For information about the Cisco Certified Refurbished Equipment program, go to: http://www.cisco.com/go/eos.
Service prices for Cisco products are subject to change after the product End-of-Sale date.
05-22-2015 03:09 AM
For 1262 Access points 2602 is the replacement Access points.
Fore reference check the table : https://supportforums.cisco.com/discussion/11743376/refreshing-access-points-environment-models
End-of-Sale Product Part Number | Product Description | Replacement Product Part Number | Replacement Product Description | Additional Information |
AIR-AP1261N-A-K9
| 802.11g/n Standalone AP; Ext Ant; A Reg Domain | AIR-SAP2602E-A-K9 | 802.11n Auto; 3×4:3SS; Mod; Ext Ant; A Reg Domain | - |
AIR-AP1261N-E-K9
| 802.11g/n Standalone AP; Ext Ant; E Reg Domain | AIR-SAP2602E-E-K9 | 802.11n Auto; 3×4:3SS; Mod; Ext Ant; E Reg Domain | - |
AIR-AP1261N-Q-K9
| 802.11g/n Standalone AP; Ext Ant; Q Reg Domain | AIR-SAP2602E-Q-K9 | 802.11n Auto; 3×4:3SS; Mod; Ext Ant; Q Reg Domain | - |
AIR-AP1262N-A-K9
| 802.11a/g/n Standalone AP; Ext Ant; A Reg Domain | AIR-SAP2602E-A-K9 | 802.11n Auto; 3×4:3SS; Mod; Ext Ant; A Reg Domain | - |
AIR-AP1262N-AK9-5 | 802.11a/g/n Standalone 5APs; Ext Ant; A Reg Domain | AIR-SAP2602E-AK9-5 | 802.11n Auto 5APs; 3×4:3SS; Mod; Ext Ant; A RegDomain | - |
AIR-AP1262N-C-K9 | 802.11a/g/n Standalone AP; Ext Ant; C Reg Domain | AIR-SAP2602E-C-K9 | 802.11n Auto; 3×4:3SS; Mod; Ext Ant; C Reg Domain | - |
AIR-AP1262N-CK9-5 | 802.11a/g/n Standalone 5APs; Ext Ant; C Reg Domain | AIR-SAP2602E-CK9-5 | 802.11n Auto 5APs; 3×4:3SS; Mod; Ext Ant; C RegDomain | - |
AIR-AP1262N-E-K9 | 802.11a/g/n Standalone AP; Ext Ant; E Reg Domain | AIR-SAP2602E-E-K9 | 802.11n Auto; 3×4:3SS; Mod; Ext Ant; E Reg Domain | - |
05-22-2015 04:28 AM
Thanks a ton guys for your suggestions..I guess I wil go for 2600 Series APs..Thanks again..:)
