10-15-2020 04:20 AM - edited 07-05-2021 12:38 PM
Dear Team:
I am trying to create wireless Bridge between to sites. The first site is where the RAP (ME Enable) is connected and the second site is where I have connected the MAP (Capwap mode). I have stablished the link mesh between converting the mesh AP to capwap because I am pretty sure it is the correct workaround.
I have followed this document:
The difference is that I am trying bridge the traffic from different VLANs however it is not working.
Solved! Go to Solution.
10-17-2020 04:24 AM
Hi all,
I solved it!
, I could bridge multiple VLANs over the mesh link. I think that issue was related to a bug on the firmware version 8.10.130.0 (recommended version). I used the firmware version 8.10.105.0 then I could converted the RAP and MAP ports from access to trunk and passed all the VLANs over there.
10-15-2020 10:24 AM
In order to bridge the traffic from different VLANs over the mesh link, VLAN Transparent feature needs to be disabled.
Dont forget to rate helpful posts
10-15-2020 12:23 PM
Hi Sandeep,
Than you so much for you reply. Yes, before I post this case, I also disabled VLAN Transparent feature.
Do you have any other idea?
Thanks again!
10-17-2020 04:24 AM
Hi all,
I solved it!
