05-15-2018 11:39 PM - edited 07-05-2021 08:38 AM
Hi All,
We are looking to create wireless bridge between 2 sites. We intend to use 1562D Access Point as autonomous APs.
I just checked this AP comes either with Lightweight Image or Mobility Express Image.
Since we won't be using any controller, my question is:
Is it possible to use 1562D for wireless bridge using Mobility Express?
Solved! Go to Solution.
01-04-2019 04:06 AM
I am facing same problem here. we have Purchased 1562I outdoor APs and our customer first requirement is Bridg mode(Point to Point connectivity)
This AP are come along with lightweight image and we convert it to Mobility express but it is of no use because Bridge mode is not supported in this image. Is there any workaround without controller?
Suhas B
01-24-2019 03:09 PM
I don't think there is any workaround.
05-16-2018 10:41 PM
Hi Guys,
Just an update. I just went through the datasheet for 1562D and it says, it could be used with Mobility Express.
Flexible deployment modes |
Allows for deployment of the 1560 in a variety of ways including point -to-point and mesh networks; it can also be deployed with the Cisco Mobility Express Solution, which is ideal f or small to medium -sized deployments that supports multiple access points without a physical controller; all deployment modes are easy to set up and configure |
05-16-2018 10:45 PM
That's true, 1562 can be act as Mobility Express. That does not allow you to have wireless bridge between given two buildings.
Hope that clears
Rasika
05-16-2018 10:51 PM
05-16-2018 11:07 PM
Yes, IW3702 support both Autonomous mode & Lightweight (Mesh/local/FlexConnect/etc)
Rasika
05-16-2018 11:22 PM
For 120m Line of Sight, which antenna would be suitable to use with IW3702 AP?
05-17-2018 02:17 AM
I would go with AIR-ANT2566P4W-R
Here is more detail about that antenna type
Rasika
05-17-2018 03:36 PM
07-15-2019 02:10 AM
I heard somewhere that wireless bridge between given two buildings is now also possible with 1562 I/E/D without controller.
Is this correct ?
I suppose with the "Lightweight AP Software" ?
What particular software version ( or above ) is needed ?
07-15-2019 03:47 PM
@ciscoazlancco wrote:I heard somewhere that wireless bridge between given two buildings is now also possible with 1562 I/E/D without controller.
Is this correct ?
Lightweight AP Software works with Controller.
Since there is no Autonomous Software available, the wireless bridge won't work without a controller.
07-25-2019 07:46 AM
So, as the far end bridged AP does has a wired connection to the controller, how will it detect the controller ? By means of a wireless connection ? Or does it need a temporally wired connections to set up, broken up afterwards ?
07-27-2019 05:16 AM
@ciscoazlancco wrote:So, as the far end bridged AP does has a wired connection to the controller, how will it detect the controller ? By means of a wireless connection ? Or does it need a temporally wired connections to set up, broken up afterwards ?
That's how we did it, temporarily wired connected the AP to set it up and then broken up.
