07-02-2004 08:26 AM - edited 07-04-2021 09:46 AM
I have an 1100 series AP and it seems to be configured properly, but every few minutes or so the connection will drop and then come back up again. It is happening on two different laptops. Both using Windows XP. 1 is using a Dell True Mobile wireless card and the other is using a Cisco 350 series wireless card. Are there any general troubleshooting steps that someone can recommend to help fix this problem? I am using 128 bit encryption and the signal strength says excellent on both laptops.
07-02-2004 09:09 AM
Try this link here
I hope it helps,
ME
12-04-2012 12:42 PM
Hello, is it possible you check this link and send the working URL ?
I am facing a similar problem... have no idea how to get that file/url ;
thanks in advance!!
