01-06-2015 02:16 AM - edited 07-05-2021 02:13 AM
Dear all,
I have Cisco WLC running Software Version 8.0.100.0 .
I connect the WLC with my LDAP ( Windown Active Directory ) to use loacl EAP authentication ( 802.1x ) using PEAP method.
i fininsh the job and my windows clients ( PCs) is working properly and my Mobile runining android is working properly too , but our iphone clients can not join the network , i receive this message " Unable to join the network .... ".
i used iPhone configuration utility to create new profile to i sent it to iphone device but still i can't join.
by the way i'm using these protocols ( 802.1x , WPA Policy-AES , PEAP)
please any help or useful information
Best Regards
abdos
01-07-2015 04:33 AM
Issues with apple, follow some of the discussions from apple forum
https://discussions.apple.com/thread/6536955?start=15&tstart=0
01-07-2015 09:19 AM
Just to add... you should upgrade to v8.0.110.0 and make sure you have FUS 1.9.0.0 also installed. As far as Apple iPhones, you should also be on the latest firmware 8.1.2. The configuration you need is 802.1x (WPA2/AES) not WPA/AES, so make sure that is set properly.
-Scott
