03-27-2020 11:03 PM - edited 07-05-2021 11:53 AM
Hello
As CAPWAP AP, the AP1701 gives maximum of 400 Mbps data rates to the clients. But when we set the AP1701 as Autonomous, it gives maximum of 144 Mbps only.
How can I get 400 Mbps in Autonomous mode ?
Cleetus
Solved! Go to Solution.
03-27-2020 11:15 PM
03-30-2020 04:01 AM
03-30-2020 06:33 AM
Best practice is to have 20 MHz channel width in 2.4 GHz and 40 MHz in 5 GHz band.
Please do a full spectrum analysis and complete review of the requirements before going into 40 MHz on 5GHz. This is not best practice to do in every situation! It depends. (VoWiFi/LBS/etc)
03-27-2020 11:15 PM
03-30-2020 03:19 AM
03-28-2020 12:57 PM
03-30-2020 03:15 AM
Thank you Scot for the response.
Following your guidelines.
Cleetus
03-30-2020 01:25 AM
Hello Cleetusant,
I'm not experienced with APs in Autonomous mode, but technically you shall be able to achieve the same data rates in both CAPWAP or Autonomous mode.
The main variables which impact the data rate are: channel width (20/40/60/... MHz), number of spatial streams (the C1701 has up to 2), Guard Interval and MCS (modulation and coding scheme). Here you have a nice overview whats possible: https://www.wlanpros.com/resources/mcs/
So your C1701 can do 400 Mbps with 40 MHz channel, two spatial streams, short guard interval and VHT MCS9 which is a 802.11ac data rate.
The 144 Mbps you have in Autonomous mode are 20 MHz channel, two spatial streams, short guard interval and HT MCS15 which is a 802.11n data rate.
So if you want to get 400 Mbps in Autonomous mode you need to set channel width to 40 MHz and enable 802.11ac data rates.
The configuration might look like that:
03-30-2020 03:14 AM
03-30-2020 04:01 AM
03-30-2020 06:33 AM
03-30-2020 07:55 AM
03-30-2020 10:12 PM
