Highlighted
Beginner
Wireless device can't get IP address for Guest network
I have a wireless network setup at my main location.  The access points allow Internal and Guest access.  The Internal access uses DHCP from a Windows Server.  The Guest access looks like it uses DHCP from my ASA, I did not set this up originally.  My question is... I am installing a new WAP in a branch location.  I can get the Internal access to work because it uses the Windows Server DHCP.  I cannot figure out how to get the Guest access configured to use the DHCP from the ASA.  The ASA is on a DMZ.  Any help would be appreciated.
version 12.4
no service pad
service password-encryption
hostname WAPMadisonOffice
logging rate-limit console 9
enable secret 5 $1$f1/9$SWBosxmjEGfSW4U.t4FnW.
no aaa new-model
dot11 syslog
dot11 vlan-name Internal vlan 141
dot11 vlan-name Guest vlan 99
dot11 ssid Bard
vlan 141
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 141500120D0A7B72757C31343017
dot11 ssid Guest
vlan 99
authentication open
guest-mode
mbssid guest-mode
wpa-psk ascii 7 070D33554F07485C4646090D162E
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 141 mode ciphers aes-ccm
encryption vlan 99 mode ciphers aes-ccm
ssid Internal
ssid Guest
antenna gain 0
mbssid
channel least-congested 2412 2437 2462
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.99
encapsulation dot1Q 99
no ip route-cache
bridge-group 99
bridge-group 99 subscriber-loop-control
bridge-group 99 block-unknown-source
no bridge-group 99 source-learning
no bridge-group 99 unicast-flooding
bridge-group 99 spanning-disabled
interface Dot11Radio0.141
encapsulation dot1Q 141
no ip route-cache
bridge-group 141
bridge-group 141 subscriber-loop-control
bridge-group 141 block-unknown-source
no bridge-group 141 source-learning
no bridge-group 141 unicast-flooding
bridge-group 141 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.99
no ip route-cache
bridge-group 99
interface GigabitEthernet0.141
no ip route-cache
bridge-group 141
interface BVI1
ip address 10.10.20.20 255.255.255.0
no ip route-cache
ip default-gateway 10.10.20.11
ip http server
ip http authentication local
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community internal RO
bridge 1 route ip
bridge 141 protocol ieee
bridge 99 protocol ieee
line con 0
logging synchronous level all
login local
line vty 0 4
login local
end
12 REPLIES 12
Highlighted
Beginner
Hi Jennifer,
I don't see any problem in your configuration.
Question: Do you have two vlan, right? vlan 141 (internal) and vlan 99 (guest)
The interface of access points are connected on switch interface with 'mode trunk'?
I think so, maybe some mistake on your switch/core configuration.
Regards.
Highlighted
Hi Rafael,
I think the issue is getting to the ASA for an IP address and getting it across the routers to the access point.  I am attaching a network drawing, router configs, and the switch config.
Highlighted
Jennifer,
The ASA is connected on this interface:
interface GigabitEthernet1/0/2
switchport trunk allowed vlan 1,10
switchport mode trunk
switchport priority extend trust
mls qos trust dscp
spanning-tree portfast
and the Access Point, what interface?
10.10.10.251 - IP of ASA?
If you set vlan 99 in one interface and connect one computer do you get ip?
I only see the interfaces 1/0/27 and 1/0/48 with access for guest vlan 99.
Regards.
Highlighted
Rafael,
The ASA is not directly connected to the switch the access point is on.  The switch port 48 connects to my router that directs traffic across the WAN.  The main switch at my main office has a direct connection to the inteface on the ASA for vlan 99.  My guest network works well in the main office.  I just cannot get it to work in the branch office across the WAN.
The access point is connected to port 27.  Those are the only two ports on that switch that should allow vlan 99 to pass through.
Highlighted
Now, I understand.
That's no one wireless issues, please, forward to "WAN, Routing and Switching".
I'm analyzing your settings.
Regards.
Highlighted
Hi Rafael,
I attached the router configs and the branch office switch in an earlier post.  Were you able to see them?  I will attach the switch config from the main office and the ASA config.
Highlighted
Hi Jennifer,
I'm checking the configuration of your devices, I didn't found anything wrong yet.
Please check the files are sent to me with passwords (remove the password from configuration).
Your question is in the wrong section, need move to switching and routing.
Try set one interface of branch site for vlan 99, if you don't get ip address fixed ip 192.168.99.80/24 and try get ping reply from your ASA GuestWLAN (192.168.99.1)
Regards.,
Rafael
Highlighted
ok, so you are trying to extend a L2 VLAN across a routed link?
That's not going to work with out doing IRB for vlan 99 across the WAN link.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Highlighted
Hi Steve,
Yes, that is what I'm trying to do.  I will do some research on IRB.
Thank you.
Highlighted
Hi Rafael,
Thanks for reminding me about the passwords.  I removed them from my first post, but forgot to on the attachments.  I removed the attachments.
I will check in to irb and maybe repost this to the switching and routing section.
Thanks.
Highlighted
Hi Jennifer,
No problem.
Stephen is correct.
Maybe this will help, http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
Regards.
Highlighted
Great.  Thank you again.
Content for Community-Ad
