Wireless LAN Controller 5508 - Web Auth - Customized
msingh2007
I have configured my WLC Controller 5508 to use Web Authentication using the Customized (Downloaded) page.  I used the WebAuth bundle and the login.tar file from it, uploaded it and It works fine.  The only issue is that if someone enters in the wrong username/password and presses submit, then it reroutes them to the Internal (Default) page half of the time.  Other half of the time, they get a message dialog from WLC indicating that the username/password combination were incorrect.  Any idea why the Internal (Default) page keeps coming up half of the time or how I can remove it?
Thanks!
17 Replies 17
I am on version 7.5.  Ran a lot of tests and still got that issue.  I think this bug has not been fixed yet.
msingh2007
FYI with version 7.5, the page doesn't work on Chrome.  So I had to roll back to 7.4 and it started to work.
msingh2007
Found the problem.  If you press the Enter key you will get the Internal page.  If you push the submit button it is fine.  So I changed the template code that Cisco provided to disable the use of the Enter key and also added a focus on the text box.
