09-13-2018 09:11 AM - edited 07-05-2021 09:10 AM
Hello all,
Due to limited budget for PS I will be reviewing and taking on doing a wireless hardware refresh of our single 5508 WLC to an H/A 3504 WLC. There's no real guide for doing the migration between hardware models. So I have to questions about the process.
1) Can the 3504s be on the same management VLAN as my existing 5508 but with different IPs?
2) The APs are on management VLAN so will that be a problem/cause an outage? Will they remained joined to the 5508 until I point them to the new 3504s?
These questions may seem rudimentary but I don't have a lab environment to vet this scenario.
Any references would be greatly appreciated too!
09-13-2018 01:48 PM
09-13-2018 01:50 PM
Pls note that 3504 can handle max 150 APs
Answer to your 2 questions as below
1. Yes
2. Unless APs are on different vlan (to WLC mgt vlan), you should be fine. AP will not learn about new 3504 IP until you do so with DHCP option 43 or DNS or static with AP primary/secondary option.
I would suggest not to configure mobility peering between 3504 & 5508
Rasika
*** Pls rate all useful responses ***
09-17-2018 07:19 AM - edited 09-17-2018 07:22 AM
Hi Rasika - I failed to mention that the APs are on the same management VLAN as the 5508. They're 3700s and have static IP address assignments. Based on what you said it looks like there could be an outage if the APs discover the 3504 on the same management VLAN as the 5508?
Thanks for your response!
09-18-2018 01:51 AM
09-13-2018 03:36 PM
