03-14-2011 08:11 AM - edited 07-03-2021 07:57 PM
Hello Guys,
I am wondering, what kind of wireless devices needed to implement netowrk for University campus, where the buildings that are not part of the main campus, but across streets. What aspects should keep in mind?
I am sincerely look forward to your assistance ans support.
03-15-2011 04:51 AM
This is a tough question and can't really be answered on a forum. You can start by looking at a Wireless LAN Controller and MESH access points especially if your concern is streets and open areas. Other than that, if you plan on deploying outdoor wireless, a site survey is the way to go.
03-28-2011 11:29 AM
Adding to what Scott already said, the site survey will not only tell you how many APs, but where to put them, what power level, what channel, etc. It will also tell you what other wireless devices are present. If it's outdoors and close to other residences and/or buildings, you're probably looking at a 5 GHz survey. That way you have more channels to use to keep your signal-to-noise ratio high and avoid interference.
Scott
03-31-2011 04:09 PM
I would say that Mesh and a WLC as they pointed out before.
Regarding the Site Survey, please check the following:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_q_and_a_item09186a00805e9a96.shtml
