431
Beginner
Wireless network in a flat LAN
Hi experts, I am tasked to setup a wireless LAN for the corporate users and guests in a corporate HQ and a VPN site connected to the HQ. The Corporate HQ has a multi VLAN environment and guest access is of no issue but the site office has only 1 flat VLAN. Is there any alternative to creating 2 different accesses for local users and guests in a flat VLAN or the only way is to have 2 VLANs in order to have corporate LAN and guest LAN? The wireless controller is located in the site office and the HQ has 2 thick APs.
I am going to create another VLAN in the HQ for guest anyway, so what types of configuration do i need to take note of if the site office has only a router (which is establishing the VPN link to the HQ) connected to a layer 2 switch for the local LAN?
Than you for your time reading this!
2 ACCEPTED SOLUTIONS
VIP Mentor
If you want you can serve site office with the subnet creating for Corporate & Guest users in HQ. As long as you register your site office AP to WLC in local mode or FlexConnect (Central Switching) all traffic come back to WLC. In this way you do not want to have seperate vlan for this in your remote site.
But if you concern about this traffic traverse VPN all the time (kind of inefficient for certain traffic flow) then you have to do local switching & need to have multiple vlan at your site office
Rasika
Highlighted
Hall of Fame Community Legend
It looks like the better option is to create another VLAN for guest in both the HQ and the site office.
For the sake of security, creating a separate subnet for guests can ensure that corporate resources will remain private.
You can restrict what guests can/can't do when you separate the subnets.
5 REPLIES 5
VIP Mentor
Rasika
Beginner
Hi Raskia,
thank you for your reply. It looks like the better option is to create another VLAN for guest in both the HQ and the site office. It is more manageable and it will be more clean to have a separate VLAN for that purpose.
Highlighted
Thanks for the ratings, Marcus.
Rising star
The authentication mechanism used to authenticate a client can be defined as Central or Local.
Central Authentication—Refers to the authentication type that involves the process of the WLC from the remote site.
Local Authentication—Refers to the authentication types that do not involve any processing from the WLC for authentication
Content for Community-Ad
August's Community Spotlight Awards
