Wireless Network is slow after putting cisco wireless controller
sanjeevmahadani
Hello Guys,
My wireless network was very good before putting Cisco WLC 4402 with version 3.2.171.6.
In my network there are two SSID's one for official and another for guest, which is working one single LAP 1142.( Total 12 LWAP is here)
we decided to manage all the ap and deployed WLC but now wireless network is very slow, local gateways is pinging with 80 ms. before WLC it was 1 ms.
Pls. suggest or come up with question to reach a solution.
reg
sanjeev
6 Replies 6
Rejohn Cuares
Level 4
Level 4
Make sure APs and WLC ports are hardcoded to full duplex/100Mbps.
Please rate replies and mark question as "answered" if applicable.
Scott Fella
The 4400 uses GLC-T's which are gigabit. So the switch needs to support gigabit. You can check your ports on the switch if it negotiates fine or not. I never had to hard code the switch ports but then again I've only felt with Cisco switches.
I would post your show run-config and also the switch port config.
-Scott
yah it's gigabit support and i have connected with fibre patch cord.
My SWITCH port config is below.
interface GigabitEthernet1/0/25
switchport mode trunk
Controller sh run
System Inventory
Switch Description............................... Cisco Controller
Machine Model.................................... AIR-WLC4402-12-K9
Serial Number.................................... FOC1105F01E
Burned-in MAC Address............................ 00:1A:6D:DD:23:00
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Press Enter to continue Or to abort
System Information
Manufacturer's Name.............................. Cisco Systems, Inc
Product Name..................................... Cisco Controller
Product Version.................................. 3.2.171.6
RTOS Version..................................... 3.2.171.6
Bootloader Version............................... 3.2.171.6
Build Type....................................... DATA + WPS
System Name...................................... SFA-CTRL2-HQ
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 10.156.11.231
System Up Time................................... 0 days 11 hrs 9 mins 43 secs
Configured Country............................... United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +38 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 115
Switch Configuration
802.3x Flow Control Mode......................... Disable
Current LWAPP Transport Mode..................... Layer 3
LWAPP Transport Mode after next switch reboot.... Layer 3
FIPS prerequisite features....................... Disabled
Network Information
RF-Network Name............................. UNISFA
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Mode..................... Disable   Mode: Ucast
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
ARP Unicast Mode............................ Disabled
Cisco AP Default Master..................... Disable
Mgmt Via Wireless Interface................. Enable
Bridge AP Zero Config....................... Enable
Bridge Shared Secret........................ youshouldsetme
Allow Old Bridging Aps To Authenticate...... Enable
Over The Air Provisioning of AP's........... Enable
Mobile Peer to Peer Blocking................ Disable
Apple Talk ................................. Disable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
Port Summary
           STP   Admin   Physical   Physical   Link   Link    Mcast
Pr  Type   Stat   Mode     Mode      Status   Status  Trap   Appliance   POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  Enable     N/A
2  Normal  Disa Enable  Auto       1000 Full  Down   Enable  Enable     N/A
AP Summary
AP Name             Slots  AP Model             Ethernet MAC       Location          Port
AP_MHQ_CMS_OFFICE    2     AIR-LAP1242AG-A-K9   00:19:30:76:75:42  default location  1
AP01-MHQ-HOM         2     AIR-LAP1242AG-A-K9   00:19:30:76:74:be  default location  1
AP01_MHQ_AIROPS      2     AIR-LAP1242AG-A-K9   00:1d:45:36:6c:84  default location  1
AP01_MSA_HOM_RES     2     AIR-LAP1242AG-A-K9   00:1d:45:36:6b:e2  default location  1
AP10-MHQ-CCITS       2     AIR-LAP1242AG-A-K9   00:19:30:76:74:82  default location  1
AP01-MSA2-TC5        2     AIR-LAP1242AG-A-K9   00:1d:45:36:6d:44  default location  1
AP01_MSA_CableTV_Room  2     AIR-LAP1242AG-A-K9   00:19:30:76:83:aa  default location  1
AP01_MSA_RUS_ROOM    2     AIR-LAP1242AG-A-K9   00:19:30:76:83:00  default location  1
AP01-MHQ-JLOC        2     AIR-LAP1242AG-A-K9   00:19:30:76:7f:d0  default location  1
AP01-MSA-C2-D        2     AIR-LAP1242AG-A-K9   00:19:30:76:74:90  default location  1
AP01_MSA_DA7         2     AIR-LAP1242AG-A-K9   00:19:30:76:80:38  default location  1
AP01_MSA_CMS_RES     2     AIR-LAP1242AG-A-K9   00:19:30:76:83:f0  default location  1
AP Config
Cisco AP Identifier.............................. 1
Cisco AP Name.................................... AP_MHQ_CMS_OFFICE
AP Regulatory Domain............................. -A
Switch Port Number .............................. 1
MAC Address...................................... 00:19:30:76:75:42
IP Address Configuration......................... Static IP assigned
IP Address....................................... 10.156.11.240
IP NetMask....................................... 255.255.254.0
Gateway IP Addr.................................. 10.156.10.1
Cisco AP Location................................ default location
Cisco AP Group Name.............................. default-group
Primary Cisco Switch.............................
Secondary Cisco Switch...........................
Tertiary Cisco Switch............................
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Remote AP Debug ................................. Disabled
S/W  Version .................................... 3.2.171.6
Boot  Version ................................... 12.3.7.1
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1242AG-A-K9
IOS Version...................................... 12.3(7)JX6
Reset Button..................................... Enabled
AP Serial Number................................. FTX1107B3U8
AP Certificate Type.............................. Manufacture Installed
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211g
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    WLAN Override ............................... Disabled
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 2
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... 00:1a:a2:d9:d3:60
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      Beacon Period ............................. 100
      DTIM Period ............................... 1
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ US
      First Chan Num ............................ 1
      Number Of Channels ........................ 11
    MAC Operation Parameters
      RTS Threshold ............................. 2347
      Short Retry Limit ......................... 7
      Long Retry Limit .......................... 4
      Maximum Tx MSDU Life Time ................. 512
      Maximum Rx Life Time ...................... 512
    Tx Power
      Num Of Supported Power Levels ............. 8
      Tx Power Level 1 .......................... 20 dBm
      Tx Power Level 2 .......................... 17 dBm
      Tx Power Level 3 .......................... 14 dBm
      Tx Power Level 4 .......................... 11 dBm
      Tx Power Level 5 .......................... 8 dBm
      Tx Power Level 6 .......................... 5 dBm
      Tx Power Level 7 .......................... 2 dBm
      Tx Power Level 8 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Current Channel ........................... 1
      TI Threshold .............................. -50
      Antenna Type............................... EXTERNAL_ANTENNA
      External Antenna Gain (in .5 dBm units).... 0
      Diversity.................................. DIVERSITY_ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 12 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
Attributes for Slot  1
    Radio Type................................... RADIO_TYPE_80211a
      Operation Rate Set
        6000 Kilo Bits........................... MANDATORY
        9000 Kilo Bits........................... MANDATORY
        12000 Kilo Bits.......................... MANDATORY
      First Chan Num ............................ 36
      Number Of Channels ........................ 4
    Tx Power
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 15 dBm
    Phy OFDM parameters
      Current Channel ........................... 36
      External Antenna Gain (in .5 dBm units).... 24
      Coverage SNR threshold..................... 16 dB
Cisco AP Identifier.............................. 2
Cisco AP Name.................................... AP01-MHQ-HOM
MAC Address...................................... 00:19:30:76:74:be
IP Address....................................... 10.156.11.238
AP Serial Number................................. FTX1107B3W4
      BSSID ..................................... 00:1a:30:e7:fc:30
      Operation Rate Set
    Tx Power
      Current Tx Power Level .................... 2
    Phy OFDM parameters
      Current Channel ........................... 11
      Diversity.................................. Side A or Right Connector
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 3
Cisco AP Name.................................... AP01_MHQ_AIROPS
MAC Address...................................... 00:1d:45:36:6c:84
IP Address....................................... 10.156.11.232
AP Serial Number................................. FTX1135B2X7
      BSSID ..................................... 00:1d:46:7e:d9:60
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 6
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 4
Cisco AP Name.................................... AP01_MSA_HOM_RES
MAC Address...................................... 00:1d:45:36:6b:e2
IP Address....................................... 10.156.11.239
AP Serial Number................................. FTX1135B2X1
      BSSID ..................................... 00:1d:46:7e:d4:30
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 149
Cisco AP Identifier.............................. 5
Cisco AP Name.................................... AP10-MHQ-CCITS
MAC Address...................................... 00:19:30:76:74:82
IP Address....................................... 10.156.11.233
AP Serial Number................................. FTX1107B3TJ
      BSSID ..................................... 00:1a:30:e7:fa:60
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 6
Cisco AP Name.................................... AP01-MSA2-TC5
MAC Address...................................... 00:1d:45:36:6d:44
IP Address....................................... 10.156.11.236
AP Serial Number................................. FTX1135B2XB
      BSSID ..................................... 00:1d:46:7e:df:70
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 64
Cisco AP Identifier.............................. 7
Cisco AP Name.................................... AP01_MSA_CableTV_Room
MAC Address...................................... 00:19:30:76:83:aa
IP Address....................................... 10.156.11.242
AP Serial Number................................. FTX1107B3TD
      BSSID ..................................... 00:1a:a2:da:46:f0
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 8
Cisco AP Name.................................... AP01_MSA_RUS_ROOM
MAC Address...................................... 00:19:30:76:83:00
IP Address....................................... 10.156.11.237
AP Serial Number................................. FTX1107B3TC
      BSSID ..................................... 00:1a:a2:da:41:b0
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 10
Cisco AP Name.................................... AP01-MHQ-JLOC
MAC Address...................................... 00:19:30:76:7f:d0
IP Address....................................... 10.156.11.245
AP Serial Number................................. FTX1107B3TB
      BSSID ..................................... 00:1a:a2:da:28:00
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 11
Cisco AP Name.................................... AP01-MSA-C2-D
MAC Address...................................... 00:19:30:76:74:90
IP Address....................................... 10.156.11.234
AP Serial Number................................. FTX1107B3TK
      BSSID ..................................... 00:1a:30:e7:fa:d0
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 9
Cisco AP Name.................................... AP01_MSA_DA7
MAC Address...................................... 00:19:30:76:80:38
IP Address....................................... 10.156.11.235
AP Serial Number................................. FTX1107B3U3
      BSSID ..................................... 00:1a:a2:da:2b:10
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
Cisco AP Identifier.............................. 0
Cisco AP Name.................................... AP01_MSA_CMS_RES
MAC Address...................................... 00:19:30:76:83:f0
IP Address....................................... 10.156.11.241
AP Serial Number................................. FTX1107B3T2
      BSSID ..................................... 00:1a:a2:da:49:20
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
      Operation Rate Set
    Tx Power
    Phy OFDM parameters
AP Airewave Director Configuration
AP Name.......................................... AP_MHQ_CMS_OFFICE
  Radio Type..................................... RADIO_TYPE_80211b/g
  Noise Information
    Noise Profile................................ PASSED
    Channel 1....................................  -94 dBm
    Channel 2....................................  -94 dBm
    Channel 3....................................  -96 dBm
    Channel 4....................................  -95 dBm
    Channel 5....................................  -92 dBm
    Channel 6....................................  -93 dBm
    Channel 7....................................  -94 dBm
    Channel 8....................................  -92 dBm
    Channel 9....................................  -95 dBm
    Channel 10...................................  -98 dBm
    Channel 11...................................  -96 dBm
  Interference Information
    Interference Profile......................... PASSED
    Channel 1.................................... -128 dBm @  0 % busy
    Channel 2.................................... -128 dBm @  0 % busy
    Channel 3.................................... -128 dBm @  0 % busy
    Channel 4.................................... -128 dBm @  0 % busy
    Channel 5.................................... -128 dBm @  0 % busy
    Channel 6....................................  -84 dBm @  1 % busy
    Channel 7.................................... -128 dBm @  0 % busy
    Channel 8.................................... -128 dBm @  0 % busy
    Channel 9.................................... -128 dBm @  0 % busy
    Channel 10................................... -128 dBm @  0 % busy
    Channel 11................................... -128 dBm @  0 % busy
  Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 5 %
    Transmit Utilization......................... 2 %
    Channel Utilization.......................... 7 %
    Attached Clients............................. 0 clients
  Coverage Information
    Coverage Profile............................. PASSED
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 0 clients
    RSSI  -68 dbm................................ 0 clients
    RSSI  -60 dbm................................ 0 clients
    RSSI  -52 dbm................................ 0 clients
  Client Signal To Noise Ratios
    SNR    0 dbm................................. 0 clients
    SNR    5 dbm................................. 0 clients
    SNR   10 dbm................................. 0 clients
    SNR   15 dbm................................. 0 clients
    SNR   20 dbm................................. 0 clients
    SNR   25 dbm................................. 0 clients
    SNR   30 dbm................................. 0 clients
    SNR   35 dbm................................. 0 clients
    SNR   40 dbm................................. 0 clients
    SNR   45 dbm................................. 0 clients
  Nearby APs
    AP 00:1a:30:e7:fc:30 slot 0..................  -62 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -77 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:2b:10 slot 0..................  -85 dBm on   6 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -87 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:46:f0 slot 0..................  -87 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -68 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -87 dBm on  11 (10.156.11.231)
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy............... unknown
    Previous Channel Average Energy.............. unknown
    Channel Change Count......................... 0
    Last Channel Change Time..................... Wed Sep 25 19:33:37 2013
    Recommendd Best Channel...................... 1
  RF Parameter Recommendations
    Power Level.................................. 1
    RTS/CTS Threshold............................ 2347
    Fragmentation Tnreshold...................... 2346
    Antenna Pattern.............................. 0
  Radio Type..................................... RADIO_TYPE_80211a
  Noise Information
    Channel 36...................................  -97 dBm
    Channel 40...................................  -98 dBm
    Channel 44...................................  -99 dBm
    Channel 48...................................  -97 dBm
    Channel 52...................................  -98 dBm
    Channel 56...................................  -97 dBm
    Channel 60...................................  -97 dBm
    Channel 64...................................  -96 dBm
    Channel 149..................................  -96 dBm
    Channel 153..................................  -96 dBm
    Channel 157..................................  -96 dBm
    Channel 161..................................  -99 dBm
    Channel 165.................................. -100 dBm
    Channel 190.................................. -101 dBm
    Channel 36................................... -128 dBm @  0 % busy
    Channel 40................................... -128 dBm @  0 % busy
    Channel 44................................... -128 dBm @  0 % busy
    Channel 48................................... -128 dBm @  0 % busy
    Channel 52................................... -128 dBm @  0 % busy
    Channel 56................................... -128 dBm @  0 % busy
    Channel 60................................... -128 dBm @  0 % busy
    Channel 64................................... -128 dBm @  0 % busy
    Channel 149.................................. -128 dBm @  0 % busy
    Channel 153.................................. -128 dBm @  0 % busy
    Channel 157.................................. -128 dBm @  0 % busy
    Channel 161.................................. -128 dBm @  0 % busy
    Channel 165.................................. -128 dBm @  0 % busy
    Channel 190.................................. -128 dBm @  0 % busy
  Load Information
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 0 %
    Channel Utilization.......................... 0 %
  Nearby APs
  Radar Information
    Recommendd Best Channel...................... 36
AP Name.......................................... AP01-MHQ-HOM
  Noise Information
    Channel 1.................................... -101 dBm
    Channel 2....................................  -97 dBm
    Channel 3....................................  -94 dBm
    Channel 4....................................  -90 dBm
    Channel 5....................................  -98 dBm
    Channel 7....................................  -96 dBm
    Channel 8....................................  -97 dBm
    Channel 9....................................  -99 dBm
    Channel 11...................................  -98 dBm
    Channel 1....................................  -71 dBm @  4 % busy
    Channel 5....................................  -74 dBm @  1 % busy
    Channel 6....................................  -77 dBm @  8 % busy
    Channel 7....................................  -70 dBm @  6 % busy
  Load Information
    Receive Utilization.......................... 3 %
    Transmit Utilization......................... 1 %
    Channel Utilization.......................... 5 %
  Nearby APs
    AP 00:1a:30:e7:fa:60 slot 0..................  -77 dBm on   1 (10.156.11.231)
    AP 00:1a:30:e7:fa:d0 slot 0..................  -84 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:d9:d3:60 slot 0..................  -70 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -34 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:2b:10 slot 0..................  -70 dBm on   6 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -68 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:46:f0 slot 0..................  -68 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -58 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -78 dBm on  11 (10.156.11.231)
  Radar Information
    Recommendd Best Channel...................... 11
    Power Level.................................. 2
  Noise Information
    Channel 36...................................  -99 dBm
    Channel 40...................................  -99 dBm
    Channel 44...................................  -98 dBm
    Channel 48................................... -100 dBm
    Channel 52................................... -102 dBm
    Channel 56...................................  -98 dBm
    Channel 60................................... -100 dBm
    Channel 64................................... -100 dBm
    Channel 149.................................. -101 dBm
    Channel 153.................................. -100 dBm
    Channel 157.................................. -100 dBm
    Channel 165.................................. -105 dBm
    Channel 190.................................. -103 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01_MHQ_AIROPS
  Noise Information
    Channel 1....................................  -97 dBm
    Channel 2....................................  -99 dBm
    Channel 4....................................  -99 dBm
    Channel 5....................................  -97 dBm
    Channel 6....................................  -98 dBm
    Channel 7....................................  -87 dBm
    Channel 8....................................  -98 dBm
    Channel 9....................................  -96 dBm
    Channel 11...................................  -99 dBm
    Interference Profile......................... FAILED
    Channel 1....................................  -63 dBm @  6 % busy
    Channel 5....................................  -78 dBm @  6 % busy
    Channel 6....................................  -78 dBm @ 11 % busy
    Channel 7....................................  -77 dBm @  6 % busy
    Channel 8....................................  -84 dBm @  2 % busy
  Load Information
    Receive Utilization.......................... 11 %
    Channel Utilization.......................... 20 %
    Attached Clients............................. 8 clients
    Coverage Profile............................. FAILED
    Failed Clients............................... 3 clients
    RSSI  -92 dbm................................ 4 clients
    RSSI  -84 dbm................................ 3 clients
    SNR   10 dbm................................. 3 clients
    SNR   15 dbm................................. 4 clients
  Nearby APs
    AP 00:1a:30:e7:fa:60 slot 0..................  -87 dBm on   1 (10.156.11.231)
    AP 00:1a:30:e7:fa:d0 slot 0..................  -73 dBm on  11 (10.156.11.231)
    AP 00:1a:30:e7:fc:30 slot 0..................  -59 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:d9:d3:60 slot 0..................  -78 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -67 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:2b:10 slot 0..................  -74 dBm on   6 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -64 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:46:f0 slot 0..................  -63 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -65 dBm on  11 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:33:39 2013
    Recommendd Best Channel...................... 6
  Noise Information
    Channel 36...................................  -98 dBm
    Channel 44...................................  -96 dBm
    Channel 48...................................  -98 dBm
    Channel 52...................................  -99 dBm
    Channel 60...................................  -95 dBm
    Channel 64...................................  -98 dBm
    Channel 153..................................  -98 dBm
    Channel 157..................................  -98 dBm
    Channel 161..................................  -98 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01_MSA_HOM_RES
  Noise Information
    Channel 3....................................  -98 dBm
    Channel 5....................................  -99 dBm
    Channel 6....................................  -97 dBm
    Channel 7....................................  -98 dBm
    Channel 8....................................  -96 dBm
    Channel 9....................................  -98 dBm
    Channel 11...................................  -95 dBm
    Channel 1....................................  -85 dBm @  1 % busy
    Channel 5....................................  -79 dBm @  4 % busy
    Channel 6....................................  -83 dBm @ 18 % busy
    Channel 7....................................  -85 dBm @  4 % busy
  Load Information
    Receive Utilization.......................... 4 %
    Transmit Utilization......................... 11 %
    Channel Utilization.......................... 15 %
    Attached Clients............................. 6 clients
    RSSI  -84 dbm................................ 1 clients
    RSSI  -76 dbm................................ 2 clients
    RSSI  -68 dbm................................ 1 clients
    RSSI  -60 dbm................................ 2 clients
    SNR   20 dbm................................. 2 clients
    SNR   25 dbm................................. 1 clients
    SNR   35 dbm................................. 1 clients
    SNR   40 dbm................................. 2 clients
  Nearby APs
    AP 00:1a:a2:da:46:f0 slot 0..................  -88 dBm on   1 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:33:40 2013
  Noise Information
    Channel 36...................................  -93 dBm
    Channel 40...................................  -94 dBm
    Channel 44...................................  -95 dBm
    Channel 48...................................  -94 dBm
    Channel 52...................................  -95 dBm
    Channel 56...................................  -94 dBm
    Channel 60...................................  -94 dBm
    Channel 64...................................  -95 dBm
    Channel 153..................................  -93 dBm
    Channel 157..................................  -94 dBm
    Channel 161..................................  -94 dBm
    Channel 165..................................  -99 dBm
    Channel 190..................................  -99 dBm
  Load Information
  Nearby APs
  Radar Information
    Recommendd Best Channel...................... 149
AP Name.......................................... AP10-MHQ-CCITS
  Noise Information
    Channel 1....................................  -98 dBm
    Channel 3....................................  -95 dBm
    Channel 6....................................  -99 dBm
    Channel 7....................................  -97 dBm
    Channel 1....................................  -77 dBm @  3 % busy
    Channel 2....................................  -72 dBm @  1 % busy
    Channel 6.................................... -128 dBm @  0 % busy
  Load Information
    Receive Utilization.......................... 2 %
    Channel Utilization.......................... 3 %
    Attached Clients............................. 1 clients
    RSSI  -52 dbm................................ 1 clients
    SNR   45 dbm................................. 1 clients
  Nearby APs
    AP 00:1a:30:e7:fc:30 slot 0..................  -78 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -78 dBm on   1 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:33:41 2013
  Noise Information
    Channel 44...................................  -97 dBm
    Channel 149..................................  -97 dBm
    Channel 153..................................  -99 dBm
    Channel 157..................................  -97 dBm
    Channel 165.................................. -101 dBm
    Channel 190.................................. -105 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01-MSA2-TC5
  Noise Information
    Channel 1....................................  -96 dBm
    Channel 2....................................  -93 dBm
    Channel 5....................................  -95 dBm
    Channel 6....................................  -96 dBm
    Channel 7....................................  -99 dBm
    Channel 9.................................... -100 dBm
    Channel 10...................................  -96 dBm
    Channel 1....................................  -65 dBm @  6 % busy
    Channel 2....................................  -60 dBm @  1 % busy
    Channel 3....................................  -67 dBm @  1 % busy
    Channel 5....................................  -80 dBm @  5 % busy
    Channel 6....................................  -72 dBm @  9 % busy
    Channel 7....................................  -76 dBm @  7 % busy
  Load Information
    Transmit Utilization......................... 3 %
    RSSI -100 dbm................................ 2 clients
    RSSI  -92 dbm................................ 2 clients
    RSSI  -84 dbm................................ 2 clients
    SNR    0 dbm................................. 1 clients
    SNR    5 dbm................................. 2 clients
    SNR   15 dbm................................. 2 clients
  Nearby APs
    AP 00:1a:30:e7:fa:d0 slot 0..................  -75 dBm on  11 (10.156.11.231)
    AP 00:1a:30:e7:fc:30 slot 0..................  -79 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -85 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:2b:10 slot 0..................  -60 dBm on   6 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -59 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:46:f0 slot 0..................  -58 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:49:20 slot 0..................  -82 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -65 dBm on   6 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:33:43 2013
  Noise Information
    Channel 36...................................  -96 dBm
    Channel 44...................................  -94 dBm
    Channel 48...................................  -95 dBm
    Channel 52...................................  -94 dBm
    Channel 64...................................  -93 dBm
    Channel 149..................................  -94 dBm
    Channel 161..................................  -96 dBm
    Channel 190..................................  -98 dBm
  Load Information
    SNR   30 dbm................................. 1 clients
  Nearby APs
  Radar Information
    Recommendd Best Channel...................... 64
AP Name.......................................... AP01_MSA_CableTV_Room
  Noise Information
    Channel 1.................................... -100 dBm
    Channel 3....................................  -88 dBm
    Channel 5....................................  -94 dBm
    Channel 8....................................  -90 dBm
    Channel 9.................................... -101 dBm
    Channel 10...................................  -99 dBm
    Channel 1....................................  -74 dBm @  6 % busy
    Channel 2....................................  -71 dBm @  1 % busy
    Channel 5....................................  -77 dBm @  8 % busy
    Channel 6....................................  -71 dBm @ 12 % busy
    Channel 7....................................  -68 dBm @  4 % busy
  Load Information
    Load Profile................................. FAILED
    Receive Utilization.......................... 8 %
    Attached Clients............................. 16 clients
    Failed Clients............................... 5 clients
    RSSI -100 dbm................................ 3 clients
    RSSI  -84 dbm................................ 8 clients
    RSSI  -76 dbm................................ 3 clients
    SNR    5 dbm................................. 4 clients
    SNR   10 dbm................................. 2 clients
    SNR   15 dbm................................. 5 clients
    SNR   20 dbm................................. 1 clients
    SNR   25 dbm................................. 2 clients
  Nearby APs
    AP 00:1a:30:e7:fa:d0 slot 0..................  -57 dBm on  11 (10.156.11.231)
    AP 00:1a:30:e7:fc:30 slot 0..................  -70 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:2b:10 slot 0..................  -48 dBm on   6 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -70 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:49:20 slot 0..................  -83 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -62 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -56 dBm on  11 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:33:44 2013
  Noise Information
    Channel 36................................... -100 dBm
    Channel 40................................... -102 dBm
    Channel 48...................................  -99 dBm
    Channel 60...................................  -99 dBm
    Channel 64...................................  -97 dBm
    Channel 190.................................. -100 dBm
  Load Information
    SNR   15 dbm................................. 1 clients
  Nearby APs
  Radar Information
AP Name.......................................... AP01_MSA_RUS_ROOM
  Noise Information
    Channel 1....................................  -91 dBm
    Channel 3....................................  -99 dBm
    Channel 4....................................  -94 dBm
    Channel 7....................................  -91 dBm
    Channel 9....................................  -94 dBm
    Channel 10...................................  -97 dBm
    Channel 1....................................  -75 dBm @ 13 % busy
    Channel 4....................................  -79 dBm @  3 % busy
    Channel 5....................................  -72 dBm @  3 % busy
    Channel 6....................................  -73 dBm @  6 % busy
    Channel 7....................................  -73 dBm @  9 % busy
    Channel 8....................................  -71 dBm @  1 % busy
  Load Information
    Receive Utilization.......................... 10 %
    Transmit Utilization......................... 6 %
    Channel Utilization.......................... 17 %
    Attached Clients............................. 26 clients
    RSSI  -92 dbm................................ 6 clients
    RSSI  -84 dbm................................ 10 clients
    RSSI  -76 dbm................................ 5 clients
    RSSI  -68 dbm................................ 3 clients
    SNR    5 dbm................................. 1 clients
    SNR   10 dbm................................. 5 clients
    SNR   15 dbm................................. 8 clients
    SNR   20 dbm................................. 6 clients
    SNR   25 dbm................................. 4 clients
    SNR   30 dbm................................. 2 clients
  Nearby APs
    AP 00:1a:30:e7:fa:d0 slot 0..................  -55 dBm on  11 (10.156.11.231)
    AP 00:1a:30:e7:fc:30 slot 0..................  -66 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:d9:d3:60 slot 0..................  -84 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -79 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:49:20 slot 0..................  -76 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -56 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -53 dBm on  11 (10.156.11.231)
  Radar Information
  Noise Information
    Channel 40...................................  -96 dBm
    Channel 52...................................  -97 dBm
    Channel 149..................................  -98 dBm
    Channel 153..................................  -95 dBm
    Channel 190.................................. -102 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01-MHQ-JLOC
  Noise Information
    Channel 2....................................  -98 dBm
    Channel 3....................................  -97 dBm
    Channel 5....................................  -96 dBm
    Channel 6....................................  -95 dBm
    Channel 11...................................  -97 dBm
    Channel 1....................................  -74 dBm @ 14 % busy
    Channel 2....................................  -73 dBm @  2 % busy
    Channel 6....................................  -83 dBm @  9 % busy
    Channel 7....................................  -76 dBm @  8 % busy
  Load Information
    Channel Utilization.......................... 27 %
  Nearby APs
    AP 00:1a:30:e7:fa:60 slot 0..................  -79 dBm on   1 (10.156.11.231)
    AP 00:1a:30:e7:fa:d0 slot 0..................  -93 dBm on  11 (10.156.11.231)
    AP 00:1a:30:e7:fc:30 slot 0..................  -35 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:d9:d3:60 slot 0..................  -80 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -84 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:46:f0 slot 0..................  -77 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -66 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -84 dBm on  11 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:33:46 2013
  Noise Information
    Channel 48...................................  -96 dBm
    Channel 56...................................  -95 dBm
    Channel 157..................................  -95 dBm
    Channel 161..................................  -97 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01-MSA-C2-D
  Noise Information
    Channel 2....................................  -95 dBm
    Channel 7....................................  -95 dBm
    Channel 9....................................  -97 dBm
    Channel 1....................................  -73 dBm @  2 % busy
    Channel 6....................................  -79 dBm @  8 % busy
  Load Information
    Receive Utilization.......................... 6 %
    Channel Utilization.......................... 8 %
    Attached Clients............................. 5 clients
    Failed Clients............................... 2 clients
    RSSI -100 dbm................................ 1 clients
    RSSI  -92 dbm................................ 1 clients
    RSSI  -76 dbm................................ 1 clients
    SNR   10 dbm................................. 1 clients
  Nearby APs
    AP 00:1a:30:e7:fc:30 slot 0..................  -84 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:2b:10 slot 0..................  -58 dBm on   6 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -54 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:49:20 slot 0..................  -86 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -76 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -75 dBm on  11 (10.156.11.231)
  Radar Information
  Noise Information
    Channel 52...................................  -96 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01_MSA_DA7
  Noise Information
    Channel 2....................................  -96 dBm
    Channel 3....................................  -90 dBm
    Channel 6....................................  -91 dBm
    Channel 9....................................  -84 dBm
    Channel 1....................................  -62 dBm @  2 % busy
    Channel 5....................................  -74 dBm @  3 % busy
    Channel 6....................................  -72 dBm @ 17 % busy
    Channel 7....................................  -68 dBm @ 10 % busy
  Load Information
    Receive Utilization.......................... 17 %
    Transmit Utilization......................... 13 %
    Channel Utilization.......................... 34 %
    Attached Clients............................. 22 clients
    Failed Clients............................... 4 clients
    RSSI  -92 dbm................................ 5 clients
    RSSI  -76 dbm................................ 9 clients
    SNR   10 dbm................................. 4 clients
    SNR   20 dbm................................. 7 clients
  Nearby APs
    AP 00:1a:30:e7:fc:30 slot 0..................  -71 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:28:00 slot 0..................  -86 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -61 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -73 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -68 dBm on  11 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:45:31 2013
  Noise Information
    Channel 56...................................  -96 dBm
    Channel 153..................................  -97 dBm
    Channel 165..................................  -98 dBm
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... AP01_MSA_CMS_RES
  Noise Information
    Channel 1....................................  -95 dBm
    Channel 1....................................  -87 dBm @  3 % busy
    Channel 5....................................  -82 dBm @  1 % busy
  Load Information
    Channel Utilization.......................... 22 %
    Attached Clients............................. 13 clients
    RSSI  -84 dbm................................ 6 clients
    SNR   15 dbm................................. 3 clients
    SNR   20 dbm................................. 4 clients
  Nearby APs
    AP 00:1a:30:e7:fa:d0 slot 0..................  -71 dBm on  11 (10.156.11.231)
    AP 00:1a:a2:da:41:b0 slot 0..................  -77 dBm on   1 (10.156.11.231)
    AP 00:1a:a2:da:46:f0 slot 0..................  -86 dBm on   1 (10.156.11.231)
    AP 00:1d:46:7e:d9:60 slot 0..................  -91 dBm on   6 (10.156.11.231)
    AP 00:1d:46:7e:df:70 slot 0..................  -72 dBm on  11 (10.156.11.231)
  Radar Information
    Last Channel Change Time..................... Wed Sep 25 19:46:07 2013
  Noise Information
    Channel 40...................................  -95 dBm
    Channel 44................................... -100 dBm
    Channel 56...................................  -99 dBm
    Channel 60...................................  -98 dBm
    Channel 161..................................  -95 dBm
    Channel 165.................................. -103 dBm
  Load Information
  Nearby APs
  Radar Information
802.11A Configuration
802.11a Network.................................. Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Mandatory
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Supported
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 1
DTPC  Status..................................... Enabled
DTIM Period...................................... 1
Fragmentation Threshold.......................... 2346
Long Retry Limit................................. 4
Maximum Rx Life Time............................. 512
Max Tx MSDU Life Time............................ 512
Medium Occupancy Limit........................... 100
Pico-Cell Status................................. Disabled
RTS Threshold.................................... 2347
Short Retry Limit................................ 7
TI Threshold..................................... -50
802.11A Advanced Configuration
AP Name                          Channel     TxPower Level
AP_MHQ_CMS_OFFICE                    36*           1*
AP01-MHQ-HOM                         36*           1*
AP01_MHQ_AIROPS                      36*           1*
AP01_MSA_HOM_RES                    149*           1*
AP10-MHQ-CCITS                       36*           1*
AP01-MSA2-TC5                        64*           1*
AP01_MSA_CableTV_Room                36*           1*
AP01_MSA_RUS_ROOM                    36*           1*
AP01-MHQ-JLOC                        36*           1*
AP01-MSA-C2-D                        36*           1*
AP01_MSA_DA7                         64*           1*
AP01_MSA_CMS_RES                     36*           1*
802.11A Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
  802.11a Global coverage threshold.............. 16 dB
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Channels....................... Country channels
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -65 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Transmit Power Update Contribution............. SNI.
  Transmit Power Assignment Leader............... 00:1a:6d:dd:23:00
  Last Run....................................... 24 seconds ago
Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds
  Channel Update Contribution.................... SNI.
  Channel Assignment Leader...................... 00:1a:6d:dd:23:00
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
    Maximum...................................... unknown
  Channel Dwell Times
    Minimum...................................... 0 days, 10 h 56 m 00 s
    Average...................................... 0 days, 11 h 06 m 24 s
    Maximum...................................... 0 days, 11 h 08 m 30 s
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... 00:1a:6d:dd:23:00
    802.11a Group Member......................... 00:1a:6d:dd:23:00
  802.11a Last Run............................... 24 seconds ago
802.11B Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
Short Preamble mandatory......................... Enabled
802.11B Advanced Configuration
AP_MHQ_CMS_OFFICE                     1*           1*
AP01-MHQ-HOM                         11*           2*
AP01_MHQ_AIROPS                       6*           1*
AP01_MSA_HOM_RES                     11*           1*
AP10-MHQ-CCITS                        1*           1*
AP01-MSA2-TC5                        11*           1*
AP01_MSA_CableTV_Room                 1*           1*
AP01_MSA_RUS_ROOM                     1*           1*
AP01-MHQ-JLOC                         1*           1*
AP01-MSA-C2-D                        11*           1*
AP01_MSA_DA7                          6*           1*
AP01_MSA_CMS_RES                      1*           1*
802.11B Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
  802.11b Global coverage threshold.............. 12 dB
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  Last Run....................................... 25 seconds ago
  Channel Dwell Times
Radio RF Grouping
  802.11b Group Mode............................. AUTO
  802.11b Group Update Interval.................. 600 seconds
  802.11b Group Leader........................... 00:1a:6d:dd:23:00
    802.11b Group Member......................... 00:1a:6d:dd:23:00
  802.11b Last Run............................... 25 seconds ago
Mobility Configuration
Mobility Protocol Port........................... 16666
Mobility Security Mode........................... Disabled
Default Mobility Domain.......................... UNISFA
Mobility Group members configured................ 1
Switches configured in the Mobility Group
MAC Address          IP Address         Group Name
00:1a:6d:dd:23:00    10.156.11.231
Interface Configuration
Interface Name................................... ap-manager
IP Address....................................... 10.156.62.91
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.156.62.1
VLAN............................................. 999
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.156.2.23
Secondary DHCP Server............................ Unconfigured
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Interface Name................................... guest_wlan
IP Address....................................... 10.156.250.2
IP Gateway....................................... 10.156.250.1
VLAN............................................. 250
Primary DHCP Server.............................. 10.156.11.231
Secondary DHCP Server............................ 10.156.10.98
ACL.............................................. Deny_Access_Guest_WLAN
AP Manager....................................... No
Interface Name................................... management
MAC Address...................................... 00:1a:6d:dd:23:00
IP Netmask....................................... 255.255.254.0
IP Gateway....................................... 10.156.10.1
VLAN............................................. 10
Secondary DHCP Server............................ 10.156.2.20
Interface Name................................... service-port
MAC Address...................................... 00:1a:6d:dd:23:01
IP Address....................................... 10.1.1.1
DHCP Protocol.................................... Disabled
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
WLAN Configuration
WLAN Identifier.................................. 1
Network Name (SSID).............................. MSA_HQ
Status........................................... Disabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
Interface........................................ management
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
Quality of Service............................... Silver (best effort)
WMM.............................................. Disabled
802.11e.......................................... Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Radio Policy..................................... All
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA1)................. Disabled
   Wi-Fi Protected Access v2 (WPA2).............. Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Auto Anchor................................... Disabled
   Cranite Passthru.............................. Disabled
   Fortress Passthru............................. Disabled
WLAN Identifier.................................. 2
Network Name (SSID).............................. GUEST_WLAN
Broadcast SSID................................... Enabled
Interface........................................ guest_wlan
DHCP Server...................................... 10.156.250.2
DHCP Address Assignment Required................. Enabled
Security
WLAN Identifier.................................. 3
Network Name (SSID).............................. Wy_Iwyg
Status........................................... Enabled
Number of Active Clients......................... 17
Security
   Wi-Fi Protected Access (WPA1)................. Enabled
Encryption:..................................... TKIP + MIC
Authenticated Key Management:................... Pre-Shared Key
WLAN Identifier.................................. 4
Network Name (SSID).............................. guest
Number of Active Clients......................... 91
Security
ACL Configuration
ACL name: Deny_Access_Guest_WLAN
                   Source                        Destination                Source Port  Dest Port
I  Dir       IP Address/Netmask              IP Address/Netmask        Prot    Range       Range    DSCP Action
1 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0            1     0-65535     0-65535  Any Permit
2  In         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17     0-65535     0-65535  Any Permit
3 Out         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           53     0-65535     0-65535  Any Permit
4 Any         0.0.0.0/0.0.0.0             10.156.2.19/255.255.255.255  Any     0-65535     0-65535  Any Permit
5 Any         0.0.0.0/0.0.0.0             10.156.2.32/255.255.255.255  Any     0-65535     0-65535  Any Permit
6  In         0.0.0.0/0.0.0.0              10.128.0.0/255.192.0.0      Any     0-65535     0-65535  Any   Deny
7 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0          Any     0-65535     0-65535  Any Permit
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Credentials Caching.............................. Disabled
Call Station Id Type............................. IP Address
Administrative Authentication via RADIUS......... Enabled
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
Accounting Servers
Index  Type  Server Address    Port    State     Tout  RFC-3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
Route  Info
Number of Routes................................. 0
Destination Network          Genmask               Gateway
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Load Balancing Info
Aggressive Load Balancing........................ Enabled
Aggressive Load Balancing Window................. 0 clients
Dhcp Scope Info
Scope: GUEST_WLAN
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 10.156.250.21
Pool End......................................... 10.156.250.254
Network.......................................... 10.156.250.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 10.156.250.1  0.0.0.0  0.0.0.0
DNS Domain.......................................
DNS.............................................. 8.8.8.8  4.2.2.2  0.0.0.0
Netbios Name Servers............................. 0.0.0.0  0.0.0.0  0.0.0.0
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
WPS Configuration Summary
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Trusted AP Policy
  Mis-configured AP Action....................... Alarm Only
    Enforced encryption policy................... none
    Enforced preamble policy..................... none
    Enforced radio type policy................... none
    Validate SSID................................ Disabled
  Alert if Trusted AP is missing................. Disabled
  Trusted AP timeout............................. 120
Untrusted AP Policy
  Rogue Location Discovery Protocol.............. Disabled
    RLDP Action.................................. Alarm Only
  Rogue APs
    Rogues AP advertising my SSID................ Alarm Only
    Detect and report Ad-Hoc Networks............ Enabled
  Rogue Clients
    Validate rogue clients against AAA........... Disabled
    Detect trusted clients on rogue APs.......... Alarm Only
  Rogue AP timeout............................... 1200
Signature Policy
  Signature Processing........................... Enabled
Press Enter to continue Or to abort
Spanning Tree Switch Configuration
STP Specification...................... IEEE 802.1D
STP Base MAC Address................... 00:1A:6D:DD:23:00
STP Topology Change Count.............. 5
STP Time Since Topology Changed........ 0 day 10 hr 58 min 2 sec
STP Designated Root.................... 4001 00:15:2B:E7:30:00
STP Root Port.......................... 1
STP Root Cost.......................... 46
STP Max. Age (seconds)................. 20
STP Hello Time (seconds)............... 2
STP Forward Delay (seconds)............ 15
STP Hold Time (seconds)................ 1
Spanning Tree Algorithm................ Enable
STP Bridge Priority.................... 32768
STP Bridge Max. Age (seconds).......... 20
STP Bridge Hello Time (seconds)........ 2
STP Bridge Forward Delay (seconds)..... 15
Spanning Tree Port Configuration
STP Port ID................................. 8001
STP Port Designated Root.................... 4001 00:15:2B:E7:30:00
STP Port Designated Cost.................... 42
STP Port Designated Bridge.................. 8001 00:24:98:B8:AC:00
STP Port Designated Port.................... 801A
STP Port Forward Transitions Count.......... 1
STP Port State.............................. Forwarding
STP Port Administrative Mode................ 802.1D
STP Port Priority........................... 128
STP Port Path Cost.......................... 4
STP Port Path Cost Mode..................... Auto
STP Port ID................................. 8002
STP Port Designated Cost.................... 46
STP Port Designated Bridge.................. 8000 00:1A:6D:DD:23:00
STP Port Designated Port.................... 8002
STP Port Forward Transitions Count.......... 0
STP Port State.............................. Disabled
--More-- or (q)uit
(Cisco Controller) >
Pls. Assist if I am missing anything.
Reg
Sanjeev
Is there any reason why you are running with such old WLC code ? I would recommend to go at least 7.0.116.0.
Do you see any link layer issues (packet drops, discards,etc) between WLC & Switch interfaces. "show interface g1/0/25" output should give some valuable information
Rasika
i would upgrade as well, but I'd also add another GLC-T to the WLC and LAG/etherchannel the interfaces.  Currently you only have 1Gbps of connecticity
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
