WiSM 2 failover for WiSM 1
AlexZmann
I have a client who has all APs on a WiSM 1, and wants to set the WiSM 2 as the secondary controller.  Are there any issues with this setup if both controllers are running the same version of code?
Thanks for the input in advance.
2 Accepted Solutions
Stephen Rodriguez
so long as the code and configs are the same, you should be right as rain
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Leo Laohoo
I have the same setup.  Works well.
As what Steve has stated, make sure your code and configs are the same.  PLUS make sure that the amount of WAPs failing over to the WiSM-1 doesn't exceed 150 WAPs per controller.  Remember the WiSM-1 has TWO controllers and each of the controller can support up to 150 WAPs.
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Leo Laohoo
