Highlighted
Contributor
wism2 upgrade
hello
i'm planning to replace a wism1 with a wism2. i've had a look at the deployment guide:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a0080b7c904.shtml
it states as a feature for wism2 - "Interoperability with other service modules and WiSM1". can anyone confirm that this means i can have a wism1 and a wism2 in the same 6500 chassis at the same time?
also, the current 6500 chassis has some modules (WS-X6408A-GBIC) that aren't listed  as "tested and compatible". has anyone experienced problems with these modules and a wism2 in the same chassis? the WS-X6408A-GBIC modules are due for replacement very soon but i was hoping to get the wism2 installed first.
thanks
andy
5 REPLIES 5
Beginner
wism2 upgrade
Hi Andy
Reassurance for you: We recently installed a WiSM 2 into a 6509 chassis, where we house some of our WiSM1 and everything is fine.
Can't comment on your module question unortunately.
regards
Highlighted
Contributor
wism2 upgrade
thanks - installed the wism2 a few weeks back and removed the WS-X6408A-GBIC modules at the same time - no problems
Highlighted
Beginner
Re:wism2 upgrade
Andrew,
So to confirm you were able to have the wism1 and the wism2 in the same chassis at the same time? Was it OIR (online insertion \ removal) ... no downtime putting it in there? Planning on updating mine soon as well... did you run into any gotchas?
Thanks for any input
Highlighted
Contributor
wism2 upgrade
hello - i had no issues installing the wism2 in the same chassis as wism 1. i upgraded the ios (redundant sup720s) and took out the old gbic modules. wism2 installed no problem.
hth
andy
Highlighted
Hall of Fame Community Legend
wism2 upgrade
WiSM-1 and WiSM-2 will work together as long as the chassis has the correct IOS to get the WiSM-2 operational.  I believe that would be SXJ version IOS.
The reason is because this line card has got nothing to do with WiSM-1 or WiSM-2.  The only thing in common is that all three line cards can be "housed" in the same chassis.
Content for Community-Ad
