322
Highlighted
Beginner
WLAN design question
Can someone tell me what the best configuration is for the following scenario:
Site1 (Head Office & Data Centre)
100 users
Site2
80 users
Site3
40 users
Site4
40 users
Site5
30 users
Each of the sites has its own Domain Controller.
My idea is to have a vWLC at Site1 and configure AP's in H-REAP/Flexconnect mode at each of the other sites with local switching and radius authentication on the local DC.
Is this a feasible design or is there a better way?
Everyone's tags (4)
6 REPLIES 6
Hall of Fame Community Legend
Are you planning to use Catalyst 3850 as your LAN switch at each site?
If you are, then you can use the 3850 to terminate 50 APs at a time and enable the WLC.
Beginner
Most switches will be 3560's.
Site 1 will have 4507.
Each site will need less than 5 AP's.
Well then, if you will have an authentication server at each site then H-REAP is a very ideal choice.
Hall of Fame Master
Re: WLAN design question
I think the max AP that is supported on a vWLC is 200? You have over 200 AP's.
-Scott
Beginner
We have over 200 users, not AP's.  We have around 25 AP's maximum.
Hall of Fame Master
Your right;:)
-Scott
Content for Community-Ad
August's Community Spotlight Awards
