WLC 2500 series
Computime SCC
As far as I can find this model comes with 4 X Gigabit ports but does not support Etherchannel or LAG .. .. can someone confirm this ? I assume this is this a hardware limitation since it uses the 7.0 code as the 5508 series right ?
Stephen Rodriguez
Correct, the 2500 does not support LAG/Etherchannel.
"An interface is a logical entity on the controller. An interface has  multiple parameters associated with it, including IP address,  default-gateway (for the IP subnet), primary physical port, secondary  physical port, VLAN tag, and DHCP server. Since LAG is not used, each  interface is mapped to at least one primary physical port and an  optional secondary port. Multiple interfaces can be mapped to a single  Wireless Controller port."
From here:  http://www.cisco.com/en/US/customer/products/ps11630/products_tech_note09186a0080b8450c.shtml#cliconfig
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Nicolas Darchis
its CPU doesn't allow for more than 300Mbps (or is it 500 ?) of real client data throughput. So there's not much point in using the other ports anyway.
