02-07-2019 01:02 AM - edited 07-05-2021 09:48 AM
We have WLC 2504 running software version 8.0.120.0, with Bootloader Version 1.0.20.
& Access Point 2600 running ios 15.3(3)JA4.
1. Correct me if am wrong... WLC update path is
8.0.120.0 --- 1st update to 8.3.143.0---- then 2nd update to 8.5.135.0
2. How to update the 2600 Access Point ios to 15.3(3)JF9.
I want to update both WLC & access point to latest stable ios.
Solved! Go to Solution.
02-07-2019 01:05 AM
You are right about upgrade path.
And You dont need to upgrade AP seperately.
once you will update your WLC to 8.5.135.0 then AP will also update his image from WLC.
Dont forget to rate helpful posts
02-07-2019 01:05 AM
02-07-2019 01:09 AM
02-07-2019 01:11 AM
yes it will. (WLC must support the AP)
Dont forget to arte helpful posts
02-07-2019 01:12 AM
