129
Highlighted
Beginner
wlc 2504 AIR-CAP1532I-E-K9 continiusly downloading
I would like to upgrade WLC 2504 from 8.2.151.0 to newe image. So I follow release note:
If you are using Release 8.2.15x or earlier, we recommend that you upgrade to Release 8.2.16x or 8.3.x and then upgrade to Release 8.5.140.0.
so I upgrade to 8.3.121.0
all device upgrade except  AIR-CAP1532I-E-K9, it is continuously downloading (Operational Status)
WLC 2504
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.121.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
I also try to upgrade to 8.5.x but again only AIR-CAP1532I-E-K9, it is continuously downloading...
How can I get it out from downloading? What can I do?
p.s. it is outside AP so I don't want to climb to it :-D
Best regards,
Ivan
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Mentor
Re: wlc 2504 AIR-CAP1532I-E-K9 continiusly downloading
Did you upload a supplementry image on 2504 WLC? This bundle is mandatory to support AP802,AP1530, AP1550 and AP1570
AIR-CT2500-AP_BUNDLE-K9-8-3-150-0.aes
https://software.cisco.com/download/home/283848165/type/280926587/release/8.3.150.0
1. disconnect AP from Switch
2. update wlc with supplementry image
3. then cconnect AP again to chekc if its getting connecte dor not!
Also recommand to use either 8.3.150.0 or 8.5.151.0 software for 2504 WLC.
Dont forget to rate helpful posts
2 REPLIES 2
VIP Mentor
Beginner
thanks for fast response, I somehow manage to miss that :-)
Best regards,
Ivan
Content for Community-Ad
August's Community Spotlight Awards
