WLC 2504 and DHCP with 3602 series WAP's
RJ RJ
George Stefanick
The WLC is really just a wireless switch. It does not do routing. If you want your wireless client to reach a different network you will need to make sure the router protocol in use is allowing this ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
abel.ortgea
As Jorge said think always the WLC as a wireless switch even if it is a WLCM (integrated module to your router)
In this case you have two networks segments, so you have to route them in your router protocol.
This segment you have in the WLC needs another vlan or sub interface
George and Abel, Thanks for the information. As I suspected. Also will I need to add this to every switch that has an AP attached to it or just the switch attached to the controller.
