WLC 2504 can't access GUI...
Zahan Al-Rashid
Hi All,
I am not sure what I have been doing wrong, the 2504 itself only has 4 ports and no management port but I have heard it is actually port 1 (even though there is no labels for it). This is what I have done so far to try and access the GUI:
in CLI mode I have
1) put AP managament address as 10.151.55.129 255.255.255.224;
2) I have enabled adminmode on port 1 which I am assuming is management port and enabling admin mode is the same as "no shut" on switches I assume; here is the command I entered:
(Cisco Controller) config>port adminmode 1 enable
3) enabled HTTPS/HTTP via commands:
(Cisco Controller) config>network secureweb enable
(Cisco Controller) config>network web-auth secureweb enable
(Cisco Controller) config>network webmode enable
4) I then did reset system and checked that changes have taken place using show network summary as shown below. I have also enabled mgmt-via-dynamic interface to see if it makes any difference:
RF-Network Name............................. TEST_WIFI
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 225.225.225.225
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Enable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80,1
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Disabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
mDNS snooping............................... Disabled
mDNS Query Interval......................... 15 minutes
5) I have setup my LAPTOP NIC to be 10.151.55.20 255.255.255.224 and connected it to port 1 on wlc 2504; but I can't ping 10.151.55.29 nor can I browse to https://10.151.55.29/. The port does appear up (green lights flashing on port 1 and laptop NIC also flashing).
Any help would be appreciated
Scott Fella
If your connecting your laptop direct to port 1, then you need to untagged the management vlan. Right now you have that configured for vlan 10, you need to set that to vlan 0.
Then you will be able to ping the management interface and connect to it via the GUI.
-Scott
20 Replies 20
Sandeep Choudhary
Hi Zahan,
(WLC) >config network webmode enable
(WLC) >config network secureweb enable
You must reboot for the change to take effect.
If you are still having the issue then try these 2 commands and check it.
config network mgmt-via-wireless enable
config network mgmt-via-dynamic-interface enable
Hope it helps.
if it still not working post the below outputs
1. WLC : show interface detailed management
2 SW : show run interface x/x (x/x- sw interface connected to WLC port 1)
Rasika
Hi guys,
I am facing one issue with cisco 2504 software ver 8.1.131.x, when am Enabling LAG on the wlc, the wlan interfaces are then mapping with the management interface which is untagged,
also if i try to tagged the mgmt interface, am not able to access the controller thru the network(meaning from the switch) . Attached snapshot
Did you try to change those dynamic interfaces mapping after enabling LAG ? If not try it out.
It is better to start a new thread for your issue
Rasika
*** Pls rate all useful responses ***
Dear Rasik,
Issue resovled ! I enabled LAG then reboot, and manually changed the wlan interfaces to their respective ones. also mgmt interface i tagged and able to access thru switch as well. Thanks for the insights.
Hi Rasik,
I am having around 300, 3700i APs out of which 170 is showing on the 8510 wlc, the hindrance am facing is that those APs which are not associated with WLC is actually connected with their access switches and from the switch i am able to ping my DHCP server which is Infoblox, but the APs are not getting the IP address. I tried the switch port shut and no shut, verifed the dhcp scopes and option 43 on the dhcp server(infoblox), but still the APs are just powered on but not getting the IP address. I also tried connecting my laptop on the same AP port on the switch , the laptop gets the IP immediately.
Can anybody has any insight where am losing or i left somtheing to config/ verify on any concerned devices??
I tried putting console into the AP and a message appears as " WLC could not discover, Renewing DHCP IP".
But am not able to see the IP , which its renewing, can you explain what am missing exactly?
I cannot ping my wireless controller, below is the output for my management IP:
Interface Name................................... management
MAC Address...................................... bc:c4:93:17:7c:8f
IP Address....................................... 192.168.30.10
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.30.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::bec4:93ff:fe17:7c8f/64
STATE ........................................... REACHABLE
Primary IPv6 Address............................. ::/128
STATE ........................................... NONE
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
STATE ........................................... INCOMPLETE
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (13)
Primary Physical Port............................ LAG (13)
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.1.2
Hi Guys,
Sandeepchoudhary21 - I tried what you have suggested but still not able to access GUI.
Rsaikanayanajith - details of interface below; it is not connected to a switch. It's current stand alone and I am trying to access GUI via port 1.
(Cisco Controller) >show interface detailed management
MAC Address...................................... f0:29:29:89:35:af
IP Address....................................... 10.151.55.29
IP Netmask....................................... 255.255.255.224
IP Gateway....................................... 10.151.55.30
VLAN............................................. 110
Primary DHCP Server.............................. 10.151.55.29
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Kashud Aftab
Those links are not for 2504; I can access GUI on other models of WLC via Service port but this one has none.
Hi Guys,
Kashud Aftab
Scott Fella
-Scott
Thanks Scott that has solved it.
No problem. The issue is that your machine isn't tagging vlan 10 so the WLC is basically ignoring that packet. Now when you do connect it to the network, you should tag the managemt interface and make sure your trunking and allowing vlan 10.
-Scott
WLC not access from the network
Hello Everyone,
I am facing some issue regarding GUI access of the WLC from my network. Let me discuss my network first. WLC directly connected with Core nexus switch and
port configuration is
description ****WLC Connected with Core Switch****
interface eth 1/10
switchport mode trunk
My WLC managemnt IP address is in VLAN 205 and interface is tagged with same vlan 205
My AP management ip is in same vlan 205
User connect with VLAN 140
Internet VALN 140 (WLC DHCP)
DHCP configured in WLC
Issue:
Issue is that i can only access my WLC when i connected with controller SSID's. when ever i try to access my WLC from my network/ LAN Infra then not able to access it. but i can ping its management IP address which is in vlan 205. Your expert help is required in this reagrd. Thanks in advance
