WLC 2504 can't access GUI...
Zahan Al-Rashid
Hi All,
I am not sure what I have been doing wrong, the 2504 itself only has 4 ports and no management port but I have heard it is actually port 1 (even though there is no labels for it). This is what I have done so far to try and access the GUI:
in CLI mode I have
1) put AP managament address as 10.151.55.129 255.255.255.224;
2) I have enabled adminmode on port 1 which I am assuming is management port and enabling admin mode is the same as "no shut" on switches I assume; here is the command I entered:
(Cisco Controller) config>port adminmode 1 enable
3) enabled HTTPS/HTTP via commands:
(Cisco Controller) config>network secureweb enable
(Cisco Controller) config>network web-auth secureweb enable
(Cisco Controller) config>network webmode enable
4) I then did reset system and checked that changes have taken place using show network summary as shown below. I have also enabled mgmt-via-dynamic interface to see if it makes any difference:
RF-Network Name............................. TEST_WIFI
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 225.225.225.225
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Enable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80,1
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Disabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
mDNS snooping............................... Disabled
mDNS Query Interval......................... 15 minutes
5) I have setup my LAPTOP NIC to be 10.151.55.20 255.255.255.224 and connected it to port 1 on wlc 2504; but I can't ping 10.151.55.29 nor can I browse to https://10.151.55.29/. The port does appear up (green lights flashing on port 1 and laptop NIC also flashing).
Any help would be appreciated
20 Replies 20
I am not sure of how to untagged the management vlan to 0. could you please help me
To untag the management interface, you set the vlan to 0.
-Scott
Dear can you sent me configuration comment for untagging the port 1 and vlan ID also I need to change please helo me now I'm standing console with putty for configuration
@Scott Fella wrote:
If your connecting your laptop direct to port 1, then you need to untagged the management vlan. Right now you have that configured for vlan 10, you need to set that to vlan 0.
Then you will be able to ping the management interface and connect to it via the GUI.
hi scott below in my wlc management interface config:
Interface Name................................... management
MAC Address...................................... bc:c4:93:17:e5:8f
IP Address....................................... 10.150.1.1
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.150.1.254
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (13)
Primary Physical Port............................ LAG (13)
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 10.150.1.2
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
IPv4 ACL......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
but i'm still cannot access either ping to management ip address directly through port 1. tq
kddiindia
Hi i too have same issue and found scott answer,
Could you guide me to configure Service-port configuration on WL C2504.
Narpan,
Dear kddiindia,
WLC service port is used for out of bound management. ip by some reason you are unable to access wlc. you can access wlc by service port ip address and its recommended your service port should different from your management vlan. by default 192.168.1.1 ip address of service port
