2503
wlc 2504 wil support Cisco 1130 g access point ?
i have stand alone cisco 1130g ap ,and wlc 2504. wlc 2504 support this ap or not ?
by
Veeramani.G
3 REPLIES 3
Re: wlc 2504 wil support Cisco 1130 g access point ?
Yes. Once you convert the AP to CAPWAP the 2504 will support the AP
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Community Legend
Hi Veeramani,
Just to add a note to the great (& accurate) info from my friend Steve (+5 "S" )
You will find this type of information in the WLC release notes (check out table 1-1
and the Cisco Unified Wireless Network Solution Components section);
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_2_110_0.html#wp976967
Cheers!
Rob
"Every fool's got a reason to feelin' sorry for himself" - Springsteen
Enthusiast
Yes it will you will just need to covnert the units as mention above from IOS to LWAPP.
You can use the upgrade command to convert the units.
ap#archive download-sw /overwrite /force-reload tftp://IP Address of the
For more details on the procedure check on my documents uploaded.
Content for Community-Ad
August's Community Spotlight Awards
