ā04-08-2019 09:28 AM - edited ā07-05-2021 10:13 AM
Dear Community,
For Smart Lic activation Internet are needed. What if management interface vlan can't access internet for the company policy reasons?
Cisco 3850 has capability to select which vlan to use to get an access to the internet. Any chance to have the same with wlc 3504?
ā04-08-2019 02:37 PM
Hi Slyfox,
Yes, WLC is required internet connectivity to activate and report the license usage on software portal Smart Licensing Guide.
Switching VLAN is not possible as far as I know. You can try any of the below option to get the License activated.
ā04-08-2019 11:41 PM
ā04-10-2019 11:57 PM
What to do with this?
WLC Software Version | 8.5.135.0 |
Smart Software Manager satellite Enhanced Edition 6.2
Smart Licensing is ENABLED
Registration:
Status: UNREGISTERED - REGISTRATION FAILED
Export-Controlled Functionality: Not Allowed
Initial Registration: FAILED on Apr 11 09:53:53 2019 IDT
Failure reason: Compatibility Error: The satellite is not currently compatible with the Smart Licensing Agent version on this product. If it has been at least ten business days since the satellite was registered, synchronize the satellite with Cisco's licensing servers to enable compatibility with older agent versions and then try the registration again.
ā04-11-2019 06:53 AM
ā04-11-2019 06:55 AM
ā04-11-2019 07:41 AM
ā04-11-2019 10:46 PM
ā04-11-2019 11:52 PM
I had a very(!) quick look at the documents, but couldn't find anything regarding the versions.
Here for you the links (for version 6.2.0):
Check the troubleshooting information in the first document.
ā05-01-2019 05:05 AM
Dear Community,
Cisco support already the third week not able to provide clear information on why Smart license can't be activated.
satellite (and logs) are visible from cisco smart account, but wlc activation stuck with
Registration:
Status: REGISTERING - REGISTRATION IN PROGRESS
Smart Account:
Virtual Account: DEFAULT
Export-Controlled Functionality: Allowed
Initial Registration: FAILED on May 01 14:45:21 2019 IDT
ā05-02-2019 02:35 AM - edited ā05-02-2019 02:41 AM
Hi Slyfox,
Try rebooting the WLC once and register. Also change the Module on the Profile from sm-license-data to All .
If its not working, run the below debug commands while registration process and paste the output here.
debug license events enable
debug license errors enable
debug license info enable
ā05-03-2019 04:23 AM
hello @Sathiyanarayanan Ravindran
Here is log an example which was provided for Cisco support team.
(Cisco Controller) >*emWeb: Apr 23 12:46:24.200: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:46:25.475: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:46:25.475: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:46:25.475: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:47:38.209: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:47:41.483: readFromWLCFifo, read success,Rcvd message msgId=8
*fp_main_task: Apr 23 12:47:41.483: wlcSlFifoRcvHandler received WLC_SL_NOTIFICATION_FROM_SA from SL
*fp_main_task: Apr 23 12:47:41.483: SA Notification received on WLC, Id:3 Message:SA notification Critical:Yes
*fp_main_task: Apr 23 12:47:41.483: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:47:41.483: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:47:41.483: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*fp_main_task: Apr 23 12:47:41.484: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:47:41.484: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:47:41.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:1 msg:WLC_SL_INFO_MSG_SUMMERY
*fp_main_task: Apr 23 12:47:41.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:2 msg:WLC_SL_INFO_MSG_USAGE
*fp_main_task: Apr 23 12:47:41.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:3 msg:WLC_SL_INFO_MSG_DETAIL
*fp_main_task: Apr 23 12:47:41.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:4 msg:WLC_SL_INFO_MSG_TECH_SUPPORT
*fp_main_task: Apr 23 12:47:41.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:5 msg:WLC_SL_INFO_MSG_UDI
*fp_main_task: Apr 23 12:47:41.484: readFromWLCFifo, read success,Rcvd message msgId=8
*fp_main_task: Apr 23 12:47:41.484: wlcSlFifoRcvHandler received WLC_SL_NOTIFICATION_FROM_SA from SL
*fp_main_task: Apr 23 12:47:41.484: SA Notification received on WLC, Id:11 Message:SA notification Critical:Yes
*fp_main_task: Apr 23 12:47:41.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*fp_main_task: Apr 23 12:47:41.484: SA Notification received on WLC, Id:16 Message:SA notification Critical:Yes
*emWeb: Apr 23 12:47:41.918: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:47:42.484: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:47:42.484: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:47:42.484: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:47:57.622: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:47:58.486: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:47:58.486: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:47:58.486: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:47:59.462: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:48:00.486: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:48:00.486: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:48:00.486: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:48:01.019: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:48:02.487: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:48:02.487: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:48:02.487: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:48:05.109: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:48:06.487: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:48:06.487: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
(Cisco Controller) >*fp_main_task: Apr 23 12:48:06.487: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:52:44.717: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:52:44.717: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:52:44.717: smartLicCallHomeGetHttpProxyIp()-call-home Http proxy :10.84.20.39
*emWeb: Apr 23 12:52:44.717: smartLicCallHomeGetHttpProxyPort()-call-home Http port :443
*emWeb: Apr 23 12:52:44.717: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
*emWeb: Apr 23 12:53:04.360: Free index available : 0
*emWeb: Apr 23 12:53:04.360: smartLicCallHomeCreateProfile()-profile Name is invalid
*emWeb: Apr 23 12:53:04.361: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:53:04.361: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:53:04.361: smartLicCallHomeGetPrivHostName()-call-home privacy hostname :WLC3504
*emWeb: Apr 23 12:53:04.361: smartLicCallHomeGetHttpProxyIp()-call-home Http proxy :10.84.20.39
*emWeb: Apr 23 12:53:04.361: smartLicCallHomeGetHttpProxyPort()-call-home Http port :443
*emWeb: Apr 23 12:53:04.361: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
*emWeb: Apr 23 12:53:47.045: Free index available : 0
*emWeb: Apr 23 12:53:47.046: Send message WLC_SL_MSG_CH_CFG to callhome, profile add
*emWeb: Apr 23 12:53:47.046: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:53:47.047: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:53:47.047: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:53:47.047: smartLicCallHomeGetPrivHostName()-call-home privacy hostname :WLC3504
*emWeb: Apr 23 12:53:47.047: smartLicCallHomeGetHttpProxyIp()-call-home Http proxy :10.84.20.39
*emWeb: Apr 23 12:53:47.047: smartLicCallHomeGetHttpProxyPort()-call-home Http port :443
*emWeb: Apr 23 12:53:47.047: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
*fp_main_task: Apr 23 12:53:48.528: readFromWLCFifo, read success,Rcvd message msgId=16
*fp_main_task: Apr 23 12:53:48.528: wlcSlFifoRcvHandler received WLC_SL_MSG_CH_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:53:48.528: wlcSLProcessCHInfoUpdateMsg() - rcvd SL msg:16
*emWeb: Apr 23 12:53:51.310: smartLicCallHomeSetEventsMode() - Set Call-home events status :1
*emWeb: Apr 23 12:53:51.310: smartLicCallHomeSetHost() - Host name :WLC3504,priv Level :0
*emWeb: Apr 23 12:53:51.310: Send WLC_SL_MSG_CH_CFG - Config privacy level:0x0 message to SL process(Call Home)
*emWeb: Apr 23 12:53:51.310: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:53:51.310: Send WLC_SL_MSG_CH_CFG - set proxy message ip:10.84.20.39 port:443 to SL process
*emWeb: Apr 23 12:53:51.310: smartLicCallHomeSetHttpProxy Http proxy ip :10.84.20.39 , port : 443
*emWeb: Apr 23 12:53:51.340: In smartLicCallHomeProfileStatusSet()- Profile name:ciscotac-1 status :1
*emWeb: Apr 23 12:53:51.340: smartLicCallHomeProfileStatusSet()- Input status is same as current TAC Profile:ciscotac-1 status :1, returning
*emWeb: Apr 23 12:53:51.340: wlcSlCallHomeSetContactEmailAddr() - Set Call-home contact email address:sch-smart-licensing@cisco.com same email already configured
*emWeb: Apr 23 12:53:51.341: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:53:51.341: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:53:51.342: smartLicCallHomeGetPrivHostName()-call-home privacy hostname :WLC3504
*emWeb: Apr 23 12:53:51.342: smartLicCallHomeGetHttpProxyIp()-call-home Http proxy :10.84.20.39
*emWeb: Apr 23 12:53:51.342: smartLicCallHomeGetHttpProxyPort()-call-home Http port :443
*emWeb: Apr 23 12:53:51.342: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
*fp_main_task: Apr 23 12:53:52.528: readFromWLCFifo, read success,Rcvd message msgId=16
*fp_main_task: Apr 23 12:53:52.528: wlcSlFifoRcvHandler received WLC_SL_MSG_CH_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:53:52.528: wlcSLProcessCHInfoUpdateMsg() - rcvd SL msg:16
*emWeb: Apr 23 12:54:20.665: smartLicCallHomeSetEventsMode() - Set Call-home events status :1
*emWeb: Apr 23 12:54:20.665: smartLicCallHomeSetHost() - Host name :WLC3504,priv Level :0
*emWeb: Apr 23 12:54:20.665: Send WLC_SL_MSG_CH_CFG - Config privacy level:0x0 message to SL process(Call Home)
*emWeb: Apr 23 12:54:20.665: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:54:20.665: In smartLicCallHomeProfileStatusSet()- Profile name:ciscotac-1 status :0
*emWeb: Apr 23 12:54:20.665: Send message WLC_SL_MSG_CH_CFG to callhome, profile status set, name:ciscotac-1 status:0
*emWeb: Apr 23 12:54:20.665: wlcSlCallHomeSetContactEmailAddr() - Set Call-home contact email address:sch-smart-licensing@cisco.com same email already configured
*emWeb: Apr 23 12:54:20.666: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:54:20.666: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:54:20.666: smartLicCallHomeGetHttpProxyIp()-call-home Http proxy :10.84.20.39
*emWeb: Apr 23 12:54:20.666: smartLicCallHomeGetHttpProxyPort()-call-home Http port :443
*emWeb: Apr 23 12:54:20.666: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
*fp_main_task: Apr 23 12:54:21.532: readFromWLCFifo, read success,Rcvd message msgId=16
*fp_main_task: Apr 23 12:54:21.532: wlcSlFifoRcvHandler received WLC_SL_MSG_CH_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:54:21.532: wlcSLProcessCHInfoUpdateMsg() - rcvd SL msg:16
*emWeb: Apr 23 12:54:29.104: smartLicCallHomeSetEventsMode() - Set Call-home events status :1
*emWeb: Apr 23 12:54:29.104: smartLicCallHomeSetHost() - Host name :WLC3504,priv Level :0
*emWeb: Apr 23 12:54:29.104: Send WLC_SL_MSG_CH_CFG - Config privacy level:0x0 message to SL process(Call Home)
*emWeb: Apr 23 12:54:29.104: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:54:29.105: Send WLC_SL_MSG_CH_CFG - unset proxy message to SL process
*emWeb: Apr 23 12:54:29.105: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:54:29.105: smartLicCallHomeClearHttpProxy :Clearing the http proxy details
*emWeb: Apr 23 12:54:29.124: In smartLicCallHomeProfileStatusSet()- Profile name:ciscotac-1 status :0
*emWeb: Apr 23 12:54:29.124: smartLicCallHomeProfileStatusSet()- Input status is same as current TAC Profile:ciscotac-1 status :0, returning
*emWeb: Apr 23 12:54:29.124: wlcSlCallHomeSetContactEmailAddr() - Set Call-home contact email address:sch-smart-licensing@cisco.com same email already configured
*emWeb: Apr 23 12:54:29.125: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:54:29.125: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:54:29.125: smartLicCallHomeGetPrivHostName()-call-home privacy hostname :WLC3504
*emWeb: Apr 23 12:54:29.125: smartLicCallHomeGetHttpProxyIp()-Http Proxy Ipaddress is not configured.
*emWeb: Apr 23 12:54:29.125: smartLicCallHomeGetHttpProxyPort()-Http proxy port is not configured.
*emWeb: Apr 23 12:54:29.125: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
*fp_main_task: Apr 23 12:54:30.533: readFromWLCFifo, read success,Rcvd message msgId=16
*fp_main_task: Apr 23 12:54:30.533: wlcSlFifoRcvHandler received WLC_SL_MSG_CH_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:54:30.533: wlcSLProcessCHInfoUpdateMsg() - rcvd SL msg:16
*emWeb: Apr 23 12:54:35.512: Send WLC_SL_MSG_CH_INFO_REQ message to SL process
*emWeb: Apr 23 12:54:35.512: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:54:36.534: readFromWLCFifo, read success,Rcvd message msgId=16
*fp_main_task: Apr 23 12:54:36.534: wlcSlFifoRcvHandler received WLC_SL_MSG_CH_INFO_UPDATE from SL
*emWeb: Apr 23 12:54:37.804: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:54:38.534: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:54:38.534: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:54:38.534: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:54:52.355: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:54:54.108: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:54:55.536: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:54:55.536: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:54:55.536: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:54:56.381: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*emWeb: Apr 23 12:54:57.283: Open /tmp/wlc-to-sl-fifo FIFO in O_WRONLY | O_NONBLOCK mode success
*fp_main_task: Apr 23 12:54:57.536: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:54:57.536: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:54:57.536: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*fp_main_task: Apr 23 12:54:58.536: readFromWLCFifo, read success,Rcvd message msgId=5
*fp_main_task: Apr 23 12:54:58.536: wlcSlFifoRcvHandler received WLC_SL_MSG_SA_INFO_UPDATE from SL
*fp_main_task: Apr 23 12:54:58.536: wlcSlProcessSAInfoUpdateMsg() - rcvd SL msg:5 , info msg id:0 msg:WLC_SL_INFO_MSG_STATUS
*emWeb: Apr 23 12:55:27.046: smartLicCallHomeGetEventsMode()-call-home profile count :1
*emWeb: Apr 23 12:55:27.046: smartLicCallHomeGetDataPrivLevel()-Data privacy level is not yet configured.
*emWeb: Apr 23 12:55:27.046: smartLicCallHomeGetHttpProxyIp()-Http Proxy Ipaddress is not configured.
*emWeb: Apr 23 12:55:27.046: smartLicCallHomeGetHttpProxyPort()-Http proxy port is not configured.
*emWeb: Apr 23 12:55:27.046: wlcSlGetCallHomeContactEmailId()- call-home contact email:sch-smart-licensing@cisco.com
ā05-06-2019 06:01 AM
Seems some call status configuration issue. Refer this for Call home station configuration Smart Licensing Configuration Through Satellite
ā05-07-2019 10:13 AM
@Sathiyanarayanan Ravindranthere is not too much to have it misconfigured
ā11-27-2019 06:03 AM
Hi slyfox,
Thank you for this post! Were you able to solve this issue ?
I actually get the very same error with my smart licensing configuration for a WLC 3504, pointing to our Satellite server.
I have already successfully configured smart licensing with Satellite on several switch models and the latest FW, FirePower.
The only difference on the WLC conf is that it is necessary to create a new call-home profile, whereas previously I only modified the URL of the CiscoTAC-1 profile to point to the satellite. With WLC, the default CiscoTAC-1 can't be modified.
Hence my WLC is still stuck with:
Registration:
Initial Registration: FAILED on Nov 26 21:00:17 2019 CET
Next Registration Attempt: Nov 26 21:16:49 2019 CET
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 89 days, 23 hours, 9 minutes, 16 seconds
any help on the subject would be welcome.
