503
Highlighted
Beginner
WLC 4400 and AP 1510 (Wireless Mesh)
Good Afternoon
Six month ago I installed and configured a wireless mesh with the equipment named. From two weeks ago one AP (MAP) restarts every day. In Wireless Lan Controller appears this logs:
"Unable to find AP entry in the database, could not process statistics information"
Someone can tell me why this happens
Thank you
Everyone's tags (5)
2 REPLIES 2
Error Message    %LWAPP-3-AP_DB_ERR1: Unable to find AP
[hex]:[hex]:[hex]:[hex]:[hex]:[hex] entry in the database, could not process
[chars]
Explanation    The operation being performed for the AP failed because the internal entry for the AP  was not found. It is possible that the AP has been removed from the controller.
Recommended Action    Use the  'show ap summary' command to determine if the AP is still joined to  the controller. If it is not, the message may be ignored. If it is still joined, restart the AP to ensure  that it has the latest configuration and contact technical assistance if the problem recurs.
I would probably start with a WLC reboot.  Depending on what code you are running, there had been an issue with the WLC uptime exceeding 473 days
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: WLC 4400 and AP 1510 (Wireless Mesh)
you can find info about your message here:
http://www.cisco.com/en/US/docs/wireless/controller/message/guide/msgs6.html
the ap seems losing connection to the wlc for some reason.
Amjad
Rating useful replies is more useful than saying "Thank you"
Content for Community-Ad
August's Community Spotlight Awards
