ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
WLC 5508 & AP NOT REGISTERING
I am hoping that you can assist
We have installed a new 5508 WLC into a new buinging and also installed new 200 AP's which are 2802i. These have been
converted to capwap using AP-type capwap command.
On the WLC, not all the AP's are showing up as connected. They do pick up an IP address in the allocated range from the
DHCP. I have checked the liciences and these are OK. The AP's that are not connected are blinking red and green.
I have checked on the config and noticed that back up boot image is 0.0.0.0
Could this be due to the CAPWAP change?
5 REPLIES 5
Highlighted
VIP Advocate
Re: WLC 5508 & AP NOT REGISTERING
Could be. Please attach a console cable to one of the affected APs and provide us with the boot log.
There is also the possibility that the AP isn't getting enough power, the 2802i require 802.3at (PoE+).
Highlighted
Beginner
AP1212.CB16#show run
AP Name : APAP1212
Admin State : Enabled
AP Mode : Local
AP Submode : None
Reboot Reason :
Primary controller name :
Primary controller IP :
Secondary controller name :
Secondary controller IP :
Tertiary controller name :
Tertiary controller IP :
AP join priority : 1
IP Prefer-mode : IPv4
CAPWAP UDP-Lite : Unconfigured
Last Joined Controller name: TEST_WLC
DTLS Encryption State : Disabled
Discovery Timer : 10
Heartbeat Timer : 30
CDP State : Enabled
Watchdog monitoring : Enabled
IOX : Disabled
RRM State : Enabled
LSC State : Disabled
SSH State : Disabled
AP Username : apuser
Session Timeout : 300
Extlog Host : 0.0.0.0
Extlog Flags : 0
Extlog Status Interval : 0
Syslog Host : 255.255.255.255
Syslog Facility : 0
Syslog Level : errors
Core Dump TFTP IP Addr :
Core Dump File Compression : Disabled
Core Dump Filename :
Client Trace Status : Enabled(All)
Client Trace All Clients : Enabled
Client Trace Filter : 0x0E00000E
Client Trace Out ConsoleLog: Disabled
WLC Link LAG status : Disabled
AP Link LAG status : Disabled
AP WSA Mode : Disabled
AP1212#
AP1212#show version
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Cisco AP Software, (ap3g3), C2802, RELEASE SOFTWARE
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sat Nov 24 22:06:45 PST 2018
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 2013.01-gf899470 (Aug 16 2018 - 15:50:45)
AP1212 uptime is 0 days, 0 hours, 4 minutes
Last reload time : Thu Feb 21 14:59:27 UTC 2019
Last reload reason : Image Upgrade
cisco AIR-AP2802I-E-K9 ARMv7 Processor rev 1 (v7l) with 1028584/648472K bytes of memory.
Processor board ID FGL2246AALV
AP Running Image : 8.5.140.0
Primary Boot Image : 8.5.140.0
Backup Boot Image : 8.5.131.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.25
Base ethernet MAC Address : 70:B3:17:7E:CB:19
Part Number : 0-000000-00
PCA Assembly Number : 800-105672-01
PCA Revision Number : A0
PCB Serial Number : FOC22441EN6
Top Assembly Part Number : 800-105672-01
Top Assembly Serial Number : FGL2246AALV
Top Revision Number : A0
Product/Model Number : AIR-AP2802I-E-K9
AP1212#PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3feda000:0x3ffae0f4
BSS: 0x3ffefb9c
Stack: 0x3f9c9f20
Heap: 0x3f9ca000:0x3feda000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
| egiga2 | SGMII | 0x00 |
Net: , egiga1, egiga2 [PRIME]
Hit ESC key to stop autoboot: 0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 0, name "part1"
Loading file 'part1/part.bin' to addr 0x02000000 with size 55558977 (0x034fc341)...
Done
SF: Detected MX25L3205D with page size 64 KiB, total 4 MiB
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2018-06-05 15:21:43 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 55557969 Bytes = 53 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4021504 Bytes = 3.8 MiB
Image 1: 51520684 Bytes = 49.1 MiB
Image 2: 15765 Bytes = 15.4 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x054f81fc
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 01ff9000, end 01fffd94 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 977924K/1048576K available (5460K kernel code, 398K rwdata, 2444K rodata, 351K init, 465K bss, 70652K reserved)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:12.5000] buginf tty flushing thread started, ttyport=bf214400
[01/01/1970 00:00:12.6200] m25p80 spi1.0: found mx25l3206, expected n25q032
[01/01/1970 00:00:13.7400] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 20, need 32
[*01/01/1970 00:00:13.8818] buginf() enabled.
[*01/01/1970 00:00:13.8904] Made it into bootsh: Jun 5 2018 07:26:40
[*01/01/1970 00:00:13.8906] bootsh build T-eb8875394ad25c6d61b54b35d0937f2f9ded3dd6-geb887539-vipendya
[*01/01/1970 00:00:13.8906] bootsh mini ramfs booted
[*01/01/1970 00:00:24.7326] 397219 blocks
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Cisco Systems, Inc.
export@cisco.com.
init started: BusyBox v1.23.2 (2018-06-05 06:58:59 PDT)
Jan 1 00:00:28 FIPS[1262]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:29.9790]
[*01/01/1970 00:00:29.9790] Authenticating ACT2 ID:AP2800
[*01/01/1970 00:00:29.9790] Authenticating SN:FOC22455D4Y
[*01/01/1970 00:00:29.9794]
[*01/01/1970 00:00:29.9795] (ACT2Boot) Hardware is Cisco (c) authentic :-)
[*01/01/1970 00:00:29.9828] Seeding /dev/urandom from ACT2
[*01/01/1970 00:00:30.6248] Reading ACT2 SUDI certificates
[*11/11/2018 23:59:59.0064] Last reload time: Nov 15 01:04:57 2018
[*11/15/2018 01:04:57.0001] Setting system time Thu Nov 15 01:04:57 UTC 2018
[*11/15/2018 01:04:57.1161] Loading kernel crypto modules
[*11/15/2018 01:04:57.2409] GCM-128 POST passed
[*11/15/2018 01:04:57.2410] GCM-256 POST passed
[*11/15/2018 01:04:57.4147] Active version: 8.5.131.0
[*11/15/2018 01:04:57.4160] Backup version: 0.0.0.0
[*11/15/2018 01:[11/15/2018 01:04:57.5600] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
04:57.5598] devi[11/15/2018 01:04:57.6500] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
ce wired0 entered promiscuous mode
[*11/15/2018 01:04:59.0883] 0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;
[*11/15/2018 01:05:04.1983] Firmware download complete
[*11/15/2018 01:05:04.1991] FIPS enc aes-ccmp Verified
[*11/15/2018 01:05:04.1992] FIPS dec aes-ccmp [11/15/2018 01:05:04.3400] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
Verified
[*11/1[11/15/2018 01:05:04.4300] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
5/2018 01:05:04.1993] FIPS enc aes-ccmp-256 Verified
[*11/15/2018 01:05:04.1994] FIPS dec aes-ccmp-256 Verified
[*11/15/2018 01:05:04.1995] FIPS enc aes-gcmp Verified
[*11/15/2018 01:05:04.1997] FIPS dec aes-gcmp Verified
[*11/15/2018 01:05:04.1998] FIPS enc aes-gcmp-256 Verified
[*11/15/2018 01:05:04.1999] FIPS dec aes-gcmp-256 Verified
[*11/15/2018 01:05:05.8767] 0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;
[*11/15/2018 01:05:10.3347] Firmware download complete
[*11/15/2018 01:05:10.3355] FIPS enc aes-ccmp Verified
[*11/15/2018 01:05:10.3356] FIPS dec aes-ccmp Verified
[*11/15/2018 01:05:10.3357] FIPS enc aes-ccmp-256 Verified
[*11/15/2018 01:05:10.3358] FIPS dec aes-ccmp-256 Verified
[*11/15/2018 01:05:10.3359] FIPS enc aes-gcmp Verified
[*11/15/2018 01:05:10.3360] FIPS dec aes-gcmp Verified
[*11/15/2018 01:05:10.3362] FIPS enc aes-gcmp-256 Verified
[*11/15/2018 01:05:10.3363] FIPS dec aes-gcmp-256 Verified
[*11/15/2018 01:05:10.8163] ifconfig: SIOCGIFFLAGS: No such device
[*11/15/2018 01:05:10.9415] Initializing NSS Firmware
[11/15/2018 01:05:14.0800] Disabling lock debugging due to kernel taint
[*11/15/2018 01:05:14.1837] stile module dp init successfully
[*11/15/2018 01:05:14.1837] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Jun 5 2018 at 07:22:48
[*11/15/2018 01:05:15.8831]
[*11/15/2018 01:05:15.8870] boot 3 build T-eb8875394ad25c6d61b54b35d0937f2f9ded3dd6-geb887539-vipendya board barbados mac 70:B3:17:7C:41:4E
[*11/15/2018 01:05:15.8903] Module: act2_driver .text=0x7f000000 data=0x7f000770 bss=0x7f000a04
[*11/15/2018 01:05:15.8903] Module: aes_generic .text=0x7f004000 data=0x7f00a460 bss=
[*11/15/2018 01:05:15.8903] Module: sha256_generic .text=0x7f00e000 data=0x7f00fbdc bss=
[*11/15/2018 01:05:15.8903] Module: sha512_generic .text=0x7f014000 data=0x7f0158c8 bss=
[*11/15/2018 01:05:15.8903] Module: hmac .text=0x7f019000 data=0x7f0195e8 bss=
[*11/15/2018 01:05:15.8903] Module: sha1_generic .text=0x7f01d000 data=0x7f01d2cc bss=
[*11/15/2018 01:05:15.8903] Module: sha1_arm .text=0x7f021000 data=0x7f021850 bss=
[*11/15/2018 01:05:15.8903] Module: gf128mul .text=0x7f025000 data= bss=
[*11/15/2018 01:05:15.8903] Module: cbc .text=0x7f02a000 data=0x7f02a4f4 bss=
[*11/15/2018 01:05:15.8903] Module: ctr .text=0x7f02e000 data=0x7f02e7c8 bss=
[*11/15/2018 01:05:15.8903] Module: ghash_generic .text=0x7f032000 data=0x7f032268 bss=
[*11/15/2018 01:05:15.8903] Module: seqiv .text=0x7f036000 data=0x7f036654 bss=
[*11/15/2018 01:05:15.8904] Module: mbedtls .text=0x7f03a000 data=0x7f0415e0 bss=0x7f041850
[*11/15/2018 01:05:15.8904] Module: aptrace .text=0x7f046000 data=0[11/15/2018 01:05:17.4800] wired0 emac 2: link up
x7f051f84 [11/15/2018 01:05:17.5500] wired0: link up
bss=0x7f052470
[*11/15/2018 01:05:15.8904] Module: ap8x .text=0x7f05a000 data=0x7f10c0c0 bss=0x7f113ad8
[*11/15/2018 01:05:15.8904] Module: mv_nss_api .text=0x7f304000 data=0x7f356680 bss=0x7f357b08
[*11/15/2018 01:05:15.8904] Module: proclikefs .text=0x7f369000 data= bss=0x7f369b80
[*11/15/2018 01:05:15.8904] Module: stile_lm_ft .text= data= bss=
[*11/15/2018 01:05:15.8904] Module: stile_lm_dp .text= data= bss=
[*11/15/2018 01:05:15.8904] Module: mtdoops .text=0x7fe79000 data=0x7fe79e34 bss=0x7fe79fa8
[*11/15/2018 01:05:15.8904] Module: ipv6 .text=0x7fe7e000 data=0x7feb3a40 bss=0x7feb5600
[*11/15/2018 01:05:15.8904] Module: llc .text=0x7fedc000 data=0x7fedc84c bss=0x7fedc9e8
[*11/15/2018 01:05:15.8904] Module: stp .text=0x7fee1000 data=0x7fee1280 bss=0x7fee143c
[*11/15/2018 01:05:15.8904] Module: crc_itu_t .text=0x7fee5000 data= bss=
[*11/15/2018 01:05:15.8904] Module: lowmemorykiller .text=0x7fee9000 data=0x7fee92f4 bss=0x7fee94a0
[*11/15/2018 01:05:15.8904] Module: p8022 .text=0x7feed000 data= bss=
[*11/15/2018 01:05:15.8904] Module: psnap .text=0x7fef1000 data=0x7fef1344 bss=0x7fef14c4
[*11/15/2018 01:05:15.8904] Module: rng_core .text=0x7fef5000 data=0x7fef5818 bss=0x7fef59d8
[*11/15/2018 01:05:15.8904] Module: udf .text=0x7fef9000 data=0x7ff09018 bss=0x7ff09194
[*11/15/2018 01:05:15.9110] barbados /tmp/SC4_1dbm.txt
[*11/15/2018 01:05:16.0320] Last reload reason : 0: unknown
Username: [*11/15/2018 01:05:24.0778]
[*11/15/2018 01:05:24.0778] Click sched monitor: schedulers = 1
[*11/15/2018 01:05:26.8664] click-config/io-real.click:131: While configuring 'todev_wired0 :: ToDevice':
[*11/15/2018 01:05:26.8664] warning: device 'wired0' is down
[*11/15/2018 01:05:26.8829] click-config/io-real.click:131: While configuring 'fromdev_wired0 :: FromDevice':
[*11/15/2018 01:05:26.8829] warning: device 'wired0' is down
[*11/15/2018 01:[11/15/2018 01:05:27.3700] wired0 emac 2: link up
05:27.3424] clic[11/15/2018 01:05:27.4400] wired0: link up
k-config/io-real.click:131: While initializing 'tohost_wired0 :: ToHost':
[*11/15/2018 01:05:27.3425] warning: device 'wired0' is down
[*11/15/2018 01:05:27.5112] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*11/15/2018 01:05:28.3452] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*11/15/2018 01:05:28.3542] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*11/15/2018 01:05:28.3548] ip6_port srcr6, ip6local fe80::72b3:17ff:fe7c:414e, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaac)
[*11/15/2018 01:05:38.5558] Create symlink /dev/mic_cert result 0
[*11/15/2018 01:05:38.5558] Loading certificates from storage...
[*11/15/2018 01:05:38.5698] SKU to radio FW
[*11/15/2018 01:05:38.8704] Generating key, this may take a while...
[*11/15/2018 01:05:43.7876] Public key portion is:
[*11/15/2018 01:05:43.7876] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCgQ6aiZStaQydb3WJCZl/ClVZa39ZhC+zEELwxyOH+jjifZtSkDl3FjU4/2xgz8ZnzEcct0pbt/Oahr45wMsAiVhbQQifZXM5t8pYVfjS5/v/26xWSyp50nNfJ7aCisvAxnnfEvQ4P5O6S6EJAas5DQemlPIFDdDQcU2jMnSrZVmJdDR29LmjVhsHlMmQsflL8yF0763IPBecXUyEJJkPeOTCJRknmM91EK6ODt7ICVPKhvMacH7h8wJmmsppzS/xFJfW9awmzLuWMGxeW+Ze4XuG+Rhe3KOGrEiBkjdzLgCO7M3MMzTnwcLtB1MNyAs/nKq4Oj+3niAmuE9vl+Izj root@m70B3177C414E
[*11/15/2018 01:05:43.7876] Fingerprint: md5 10:2a:a7:2c:1a:89:49:c5:20:eb:9c:f5:2b:3c:0b:45
[*11/15/2018 01:05:43.7991] Starting monit
[*11/15/2018 01:05:44.0645] New Monit id: 3e2a9289eb9164c66ead2c7c49bb5e18
[*11/15/2018 01:05:44.0645] Stored in '/var/.monit.id'
[*11/15/2018 01:05:44.0647] Starting Monit 5.18 daemon with http interface at [*]:2812
[*11/15/2018 01:05:46.9337] starting tam services using ACT2...
[*11/15/2018 01:05:47.3879] Password for 'Cisco' changed
[*11/15/2018 01:05:47.7013] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_XOR_5G_FILE__/\/radio_fw\/X5.csv/g' -e 's/__EVM_POWER_XOR_5G_FILE__/\/radio_fw\/EVM_X5.csv/g' -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/1/g' -e 's/__DOMAIN_5G__/12/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-AP2802I-E-K9/g' -e 's/__AP_TYPE__/56/g' -e 's/__WIRELESS_MAC__/70:B3:17:94:48:C0/g' -e 's/__WIRED_MAC__/70:B3:17:7C:41:4E/g' -e 's/__WIRED1_MAC__/70:B3:17:7C:41:4E/g' | DMALLOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*11/15/2018 01:05:49.0404] Stopped Radio 0
[*11/15/2018 01:05:49.0531] DOT11_DRV[0]: set_channel Channel set to 6
[*11/15/2018 01:05:49.6223] Stopped Radio 1
[*11/15/2018 01:05:49.6351] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:49.8829] CRIT-MeshControl:
[*11/15/2018 01:05:49.8830] Mesh Control: skipped adding wired1 backhaul
[*11/15/2018 01:05:49.8850] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*11/15/2018 01:05:49.8855] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*11/15/2018 01:05:50.1468] DOT11_DRV[0]: set_channel Channel set to 1
[*11/15/2018 01:05:50.4520] DOT11_DRV[0]: set_channel Channel set to 1
[*11/15/2018 01:05:50.4619] DOT11_DRV[0]: set_channel Channel set to 1
[*11/15/2018 01:05:50.9109] bftype is 6
[*11/15/2018 01:05:50.9238] DOT11_DRV[0]: set_channel Channel set to 1
[*11/15/2018 01:05:51.2804] DOT11_DRV[0]: set_channel Channel set to 1
[*11/15/2018 01:05:51.5925] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:51.8998] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:52.2036] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:52.2135] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:52.6768] bftype is 6
[*11/15/2018 01:05:52.6901] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:53.0604] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:53.4231] DOT11_DRV[1]: set_channel Channel set to 36
[*11/15/2018 01:05:57.5193] Waiting for uplink IPv4 configuration
[*11/15/2018 01:05:57.6857] ethernet_port wired0, ip 192.168.1.141, netmask 255.255.255.0, gw 192.168.1.1, mtu 1500, bcast 192.168.1.255, dns1 192.168.1.1, domain TEST.DOMAIN, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*11/15/2018 01:06:08.6253] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*11/15/2018 01:06:08.6260] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*11/15/2018 01:06:08.6465] AP IPv4 Address updated from 0.0.0.0 to 192.168.1.141
[*11/15/2018 01:06:09.3709] dtls_init: Use SUDI certificate
[*11/15/2018 01:06:09.3712]
[*11/15/2018 01:06:09.3712] CAPWAP State: Init
[*11/15/2018 01:06:09.3717]
[*11/15/2018 01:06:09.3717] Config not found, PNP is required, Starting PNP
[*11/15/2018 01:06:10.8805] Failed to start timer, NULL timer handle
Username: Cisco
Password:
AP1212>show run
% Invalid input detected at '^' marker.
AP1212>enable
Password:
AP1212#show running-config
AP Name : AP1212
AP Mode : Local
AP Submode : None
Reboot Reason :
IP Prefer-mode : Unconfigured
CDP State : Enabled
IOX : Disabled
RRM State : Enabled
AP Username : Cisco
Extlog Host : 255.255.255.255
Extlog Flags : 0
Syslog Facility : 0
Client Trace Filter : 0x0000000E
AP1212#
AP1212#show version
Cisco Systems, Inc.
export@cisco.com.
Compiled Tue Jun 5 07:27:33 PDT 2018
BOOTLDR: U-Boot boot loader Version 2013.01-gad8bd06 (Sep 28 2017 - 17:03:04)
AP1212 uptime is 0 days, 0 hours, 2 minutes
Last reload time : Thu Nov 15 01:04:57 UTC 2018
Last reload reason : unknown
cisco AIR-AP2802I-E-K9 ARMv7 Processor rev 1 (v7l) with 1028584/581548K bytes of memory.
Processor board ID FGL2246AAWG
AP Running Image : 8.5.131.0
Primary Boot Image : 8.5.131.0
Backup Boot Image : 0.0.0.0
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : NOT MOBILITY EXPRESS CAPABLE
2 802.11 Radios
NSS FW version : 2.4.24
PCB Serial Number : FOC22445D4Y
Top Assembly Serial Number : FGL2246AAWG
AP1212#
Highlighted
VIP Advocate
I'm confused, is that the same AP or two different ones with the same name?
I'm asking because once it has software 8.5.140.0 and once 8.5.131.0. Are you maybe running two controllers in the same vlan with different software?
While rechecking your output, it really looks like those are two different units (different serial numbers).
The second one is running Mobility Express image, please convert it to capwap, by entering enable mode and then type 'ap-type capwap'. It should reboot and connect to your WLC 5508.
Regarding the 5508, have you enabled an European country (show country)?
Have you enabled the license (show license)?
Highlighted
Beginner
AP is on UTC and WLC is on European time. I would have thought that the AP would have got that information/time from the WLC.
Highlighted
VIP Advocate
Not just time, the configured country must match the AP model, in your case -E- models, which stands for Europe (and some other countries).
Can you please show the output of:
show country
show license
Content for Community-Ad
