10-04-2013 05:29 AM - edited 07-04-2021 01:00 AM
Hi Team,
Just i want to know below configuration are possible with WLC 5508.
Can we define specific timing to keep an account enabled. For e.g. 9:00AM to 9:00 PM from <x> date to <y> date?
- Can we authenticate the “lobby admin” user through TACACS?
- Can we enforce password change for guest user when he login for the first time?
Jana
10-04-2013 09:32 AM
You can do that in TACACS with Cisco ACS, it has date/time options.
It depends on where you create guest user account. If you use ISE guest portal, yes, all possible. WLC is not designed to do this tricks.
10-04-2013 12:01 PM
Regarding your first question
yes, you can do that
& second question Can we enforce password change for guest user when he login for the first time?
We can do that with guest portal.
10-04-2013 01:20 PM
ans:- Yes through if you integrate WLC through ISE then its possible:-
Step 1 Choose Administration > Web Portal Management > Sponsor Group Policy.
Step 2 Click the Action icon and choose an option.
Step 3 Enter a name for the new policy.
Step 4 Choose the identity group to be associated with the policy.
Step 5 (Optional) Choose additional conditions by choosing one of these options:
•Select Existing Condition from Library to choose an existing simple, compound, or time and date condition
•Create New Condition to choose an attribute, operator, and value from the expression builder.
Step 6 Choose the sponsor group to associate with this sponsor group policy.
Step 7 Click Save.
for this you need ACS as ISE dont suport TACACS right now.
Yes through ISE its possible.
