WLC 5508 FlexConnect problem
gimp
I've a Cisco WLC 5508 with 65 access point attached to it and 16 WLANs configured in FlexConnect. I have upgraded the WLC software with the 8.5.135 version and now I have two problem.
First, I can save the configuration via HTTP web console.
Second, In a WLAN configured and already present in the past inside the wlc config or when I try to configure a new WLAN with the FlexConnect Local Switching enabled and apply it, the following message  comes back:
"FelexConnect Local Switching::Request Failed - Cannot Configure WLAN with 32 Byte profile as Local switching".
How ca i resolve it ?
thanks
Michele
2 Accepted Solutions
I see that the new version doesn't accept apexs in the WLAN Profile name. I've changed the name from "Axis Chiesa Sant'Urbano Counters" to "Axis Chiesa SantUrbano Counters" and I resolved the problem.
For the first problem, the save configuration from Web console, I don't know why it doesn't work
Sorry,
but I resolved also the second problem: it was enough to logout and login again
Michele
Jurgens L
Level 3
Level 3
Did you try with other web browsers and is there any error you get?
What is the WLAN ID number of the SSID and the name of the Profile?
Sorry,
Michele
That's the reason why I wanted to check what you had as your profile name since the WLC can be picky about certain character selections.
Good job for picking it up.
