12-01-2019 10:07 AM - edited 07-05-2021 11:22 AM
Hey guys,
I have a central 5508 wlc and a lof of access points in branch offices.
Branch offices are connected via Site to Site VPN.
All AIR-LAP1142 access points in our branch offices are connected to the central wlc.
Now, we got a new branch office for which I prepared a new access point.
What I did on the ap:
lwapp ap ip address 10.10.10.10 255.255.255.0
lwapp ap ip default-gateway 10.10.10.254
lwapp ap controller ip address 192.168.1.10
My problem now is that the ap doesn't connect to the wlc.
Are there any commands to force the connection?
I can ping the ap, there are no connectivity issues.
Am I missing configuration steps.
Where should the ap appear in wlc gui?
Thank you very much!
12-01-2019 11:47 AM
What version software does your WLC run, the LWAPP command normally is used for legacy code. You should rather use the CAPWAP command as it's discovery process is much more robust than LWAPP and have dynamic MTU.
Are you sure you have your subnet mask is correct or was this just a typo on the post?
12-01-2019 11:52 AM
wlc does run software version 8.5.151.0.
I wanted to use CAPWAP command but it's not available. Is that normal?
Only lwapp command is available.
(You are right, that was a typo. I fixed it.)
12-01-2019 03:36 PM
1140 is not supported after 8.4.X.X (and later).
12-01-2019 11:39 PM
Sorry I gave you a wrong information.
Software version on wlc is 8.3.150.0
How shall I proceed? capwap command is not available on the ap, only lwapp.
12-02-2019 12:40 AM
12-01-2019 07:46 PM
Most likely the code you run on the AP must be very old that don't support that CAPWAP command. The bigger problem you have as mentioned by @Leo Laohoo is your software version on the WLC.
You will need to check out the device Cisco Wireless Solutions Software Compatibility Matrix
Always double-check the release notes of the WLC software code versions as they will indicate what AP's are supported.
12-01-2019 11:40 PM
Sorry I gave the wrong information. Software version on wlc is 8.3.150.0
12-02-2019 08:56 AM
12-03-2019 01:14 AM
I did a factory reset but couldn't use the capwap command. There is only lwapp command available.
12-03-2019 01:52 AM
12-03-2019 06:27 AM - edited 12-03-2019 06:29 AM
AP:show version:
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 21-Nov-08 01:28 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
AP0022.bd1a.c016 uptime is 42 minutes
System returned to ROM by reload
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
Last reload reason:
cisco AIR-LAP1142N-E-K9 (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1337W0JH
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:BD:1A:C0:16
Part Number : 73-11451-06
PCA Assembly Number : 800-30554-03
PCA Revision Number : A0
PCB Serial Number : FOC13344LS2
Top Assembly Part Number : 800-31273-01
Top Assembly Serial Number : FCZ1337W0JH
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-E-K9
Configuration register is 0xF
AP:show ip int b:
GigabitEthernet0 10.10.10.10 YES other up up
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.150.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... x
System Location.................................. x
System Contact................................... x
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... 192.168.1.10
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 178 days 7 hrs 24 mins 6 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries : CH,DE,GB,GR,J2,NL,NO,SG,US
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +34 C
External Temperature............................. +17 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 7
Number of Active Clients......................... 216
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 88:43:E1:62:05:00
Power Supply 1................................... Present, Power Off, Fan On
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
(Cisco Controller) >show time
Time............................................. Tue Dec 3 15:22:48 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
12-03-2019 01:01 PM
Based on the serial number of the AP, I can determine the AP to be >10 years old.
Did anyone read this: Field Notice: FN - 63942 - Wireless Lightweight Access Points and WLAN Controllers Fail to Create CAPWAP/LWAPP Connections Due to Certificate Expiration
12-03-2019 07:31 AM
Since the ap is a LAP1142, that is defined as an lwapp ap and the capwap command is only available in the newer models. The command does the same thing, it just depends on the model.
12-01-2019 11:57 AM
From the Branch do you have reachability to Controller IP, you able to ping from Branch network this first steps to check. ?
