Beginner
WLC 5760 - AP2600i failed to join ap-group after reboot
We're deploying a couple of 2600i with an WLC 5760.
We've configured an AP group, named it "factory", and then issued the command ap name AP<ip mac address> ap-groupname factory for both APs. After the restart, both AP were on the AP-Group factory.
The problem is that is we reboot or power off the APs, one will join automatically the AP-Group factory and the other goes to default-group and requires the ap name APAPf872.ead7.31da ap-groupname factory to join the AP group factory again.
Any suggestion? Is it possible to forced the ap-group configuration directly on the cli of the AP?
WLC1#sh ap groups
Site Name: default-group
Site Description:
WLAN ID   WLAN Name                        Interface
AP Name                          Slots AP Model             Ethernet MAC      Location      Port                   Country Priority GroupName
Site Name: factory
Site Description:
WLAN ID   WLAN Name                        Interface               Radio
APf872.eaa6.fc69                 2     2602I                f872.eaa6.fc69 default location Te1/0/1                PT      1
APf872.ead7.31da                 2     2602I                f872.ead7.31da default location Te1/0/1                PT      1
debug ap group
(AP joining the apgoup factory)
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 1 for ap APf872.eaa6.fc69  apgroup factory
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 2 for ap APf872.eaa6.fc69  apgroup factory
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 3 for ap APf872.eaa6.fc69  apgroup factory
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 4 for ap APf872.eaa6.fc69  apgroup factory
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 5 for ap APf872.eaa6.fc69  apgroup factory
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 6 for ap APf872.eaa6.fc69  apgroup factory
Sep 17 18:24:24.420: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 7 for ap APf872.eaa6.fc69  apgroup factory
(AP joining the default-group)
Sep 17 18:30:36.078: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 0 for apVapId 1 for ap APf872.ead7.31da  apgroup default-group
Sep 17 18:30:36.078: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 0 for apVapId 2 for ap APf872.ead7.31da  apgroup default-group
Sep 17 18:30:36.078: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 0 for apVapId 3 for ap APf872.ead7.31da  apgroup default-group
Sep 17 18:30:36.078: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 7 for apVapId 4 for ap APf872.ead7.31da  apgroup default-group
Sep 17 18:30:36.078: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 0 for apVapId 5 for ap APf872.ead7.31da  apgroup default-group
Sep 17 18:30:36.078: apfRadioPolicySiteTableEntryGet: 1 wcm:  found radio Policy 0 for apVapId 6 for ap APf872.ead7.31da  apgroup default-group
Kind regards,
Vasco Costa
Cheers,
Vasco
Everyone's tags (3)
1 REPLY 1
Highlighted
Beginner
We've used a another group of 2600i APs and it seems that this problem only occous with AP "APf872.ead7.31da" so this is not a WLC problem.
closing case
Cheers,
Vasco
Content for Community-Ad
August's Community Spotlight Awards
