265
Beginner
WLC 9800 AP not broadcasting SSID
I have assigned tags to my AP, it is registered and admin status is Enabled. The radioes had admin Enabled but operational status Down. Even though It is up now so I do not see any SSIDs
What may be a reason behind that ?
3 REPLIES 3
Re: WLC 9800 AP not broadcasting SSID
Hi @piotrPaszk
I never work before with 9800, but in old WLC, country code configured on the 9800 and choose and WLAN ID > 16 could be the issue.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
Beginner
Please check the following:-
  • Verify that Country on WLC code matches with the AP model number.
  • AP is getting required power for radios to operate.
  • 802.11b/g/n and 802.11 a/n/ac are enabled under wireless.
  • Check if AP's in proper AP group which has the required SSID.
  • SSID is in enabled state.
  • SSID is being broadcasted.
Kamaljeet
Highlighted
Participant
Ensure your AP get sufficient PoE power. For example, if you have a 2800 series model AP, you will need PoE+ or 802.11at
Content for Community-Ad
August's Community Spotlight Awards
