09-17-2019 05:05 AM - edited 07-05-2021 11:01 AM
Having an issue with the 9800 controller setup in sso, where I cant get clients to get a dhcp reply. The aps are up.. the ssid are up.. but external dhcp not so much
I have tried setting it up globally under policy without effect. I have tried setting up the svi with an helper and I can reach the dhcp server . but traffic comes back on the mgmt intf (ap intf) been looking everywhere for some good guides on the 9800 regarding dhcp externally (also the vrf options) does anyone have any good tips here=?
05-26-2020 06:16 AM
05-26-2020 06:51 AM
09-30-2020 01:39 PM
i have this issue too,
Did anyone resolve this?
09-30-2020 01:41 PM
i am not using SVI on the c9800, the ip helpers are on teh upstream core switches. when ipv4 is required, i am not getting clients stuck in ip learn, but when unchecked they get dhcp fine.
09-30-2020 01:45 PM
when ipv4 is required, i am getting clients stuck in ip learn, but when off they get dhcp fine
09-30-2020 03:33 PM
When you tick "IPv4 DHCP Required", did you configure the DHCP server IP address on the next field ? If not try it.
Rasika
10-01-2020 06:19 AM
Yes. I did put an ip in that field
10-20-2020 03:16 AM - edited 10-20-2020 03:35 AM
Hi Folks,
Same issue here.
Other interesting post:
For info, here are Bugs I found related to DHCP:
CSCvs03177 : Client stuck in IP learn state with FlexConnect local switching + central DHCP + DHCP required.
CSCvr86358: Cat9800 sourcing DHCP proxy packets using SrcIP SVI but vlan tag of wireless mgmt interface.
We are now running version: 16.12.4a
APs are in Flexconnect mode.
We have a SVI configured for each Centrally-switched WLAN . This is mandatory in order to have DHCP relay function working on the c9800 WLC.
The best practice document states the following about DHCP relay:
"the DHCP address will be sourced from the IP address of the client SVI and routed out of the interface that matches the destination (IP address of the DHCP server) in the routing table."
However, I have discovered (thanks to this post) that there is still the option (CLI & GUI) to make sure it is the case:
interface VlanXXX
description centrally-switched WLAN
ip vrf forwarding myVRF
ip dhcp relay source-interface VlanXXX
ip address 10.0.0.254 255.255.255.0
ip helper-address 10.20.0.2
end
Edit: Cisco Catalyst 9800 Series Wireless Controller does not support VRFs or routing protocols. I will delete the SVIs and Configure the DHPC relay on the upsteam switch then.
04-19-2021 06:01 AM
hi,
I have the same issue as well like yours, running flexconnect and put the ip helper address at the Local gateway SVI however for laptop's all working fine but got "IP Learn State" for CIsco wireless Dect Phone 8821 and just get no clue what going on with it. I plan to upgrade the firmware to 16.12.5 since you mentioned it was a bug for 16.12.4a firmware.
Please advise if anyone has more clue on this issue.
04-19-2021 06:07 AM
Have you tried disabling "IPv4 DHCP Required" option? I've been having strange behaviours in 16.12 regarding this feature and I would suggest disabling it.
04-19-2021 06:41 AM
Is it at policy profile advance tab?
As i remember i did not enable this.
04-19-2021 06:53 AM
Yes, parameter is under Policy Profile > Advanced > DHCP > IPv4 DHCP Required
04-19-2021 07:12 AM
yup confirm that i did not turn on this, i just let the local traffic flow to local switching gateway SVI and let ip helper redirect to the respective dhcp server.
i think i shall try the upgrade firmware to 16.12.5 if see have luck.
06-01-2021 02:26 PM - edited 06-01-2021 02:26 PM
Did upgrading help? I seem to be having this same problem. I am also on version 16.12.4a
06-09-2021 01:01 AM
For my problem upgraded firmware doesn't help but found the issue is from CUCM DSCP configuration itself which cause the Wireless Ip phone can't work properly.
