10-23-2020 05:53 AM - edited 07-05-2021 12:41 PM
So I know have a problem regarding the access-points. Prime Infrastructure is reporting interfaces shutting down.
In my WLC all AP's are joined. What could those missing AP's be?
Solved! Go to Solution.
10-25-2020 03:54 AM
"Prime Infrastructure is reporting interfaces shutting down." - an interface down is not the same as an AP down. A dual band AP generally has at least 3 interfaces - 1 LAN and 2 radio. What interface is down on what device? Could be that 2.4G radio interface is shutdown on some APs because you have FRA enabled for example.
10-23-2020 06:04 AM
Required more investigation, as per the AP it was down, WLC should see also down.
Why this was still associated with WLC ? required to clarify more informatonm is this really exists ? or showing wrong informaiton ?
10-23-2020 06:38 AM
10-25-2020 03:54 AM
10-27-2020 12:52 AM
Oh yeah, you absolutely right. Here are two examples,
"802.11a/b/g/n/ac interface of AP [hostname-xxx] is down"
"802.11a/n interface of AP [hostname-xxx] is down"
11-09-2020 06:11 PM - edited 11-09-2020 06:12 PM
if you still see the Aps admin status is up in the wlc, then try to resync your wlc in the prime infra.
