Highlighted
Beginner
WLC Clean Air - AP Reboot
Good Day.
I have a 5508 WLC, and need to enable Clean Air.
I have no access to a LAB environment, and need to know if the AP will reboot after the Clean Air is enabled ?
Also, when I need to change the "channel list" in the DCA page on the 2.4gHz radios ?
Kind Regards
1 ACCEPTED SOLUTION
Highlighted
DCA can not be adjusted without interruption and the next DCA run can/will change the channels again and thus can cause a short interruption.
[edit]
Corrected my answer
7 REPLIES 7
Highlighted
Hall of Fame Community Legend
No.  It won't.
Highlighted
Thanx Leo !
You 100% sure ?   Dont wan't to bring down the whole network . . .. .
Highlighted
Don't believe me?  Open a TAC Case.
Highlighted
and for the second part of my question ?
Highlighted
The radios need to be turned OFF before you can change the channels list.
Highlighted
[edit]
Corrected my answer
Highlighted
Beginner
Cisco CleanAir is a spectrum intelligence solution designed to proactively manage the challenges of a shared wireless spectrum. It allows you to see all of the users of the shared spectrum (both native devices and foreign interferers). It also enables you or your network to act upon this information.
Content for Community-Ad
