01-05-2011 02:08 PM - edited 07-03-2021 07:37 PM
I wonder if there is a way to save the WLC configuration as a .txt file or a copy start to tftp command like in a switch or router in order to later paste or load it to another or the same WLC.
This is because I am about to add a backup WLC in my network which only difference will be name and IP address therefore I hope I can avoid going step by step through it's configuration. Or lets say I restore default settings in my current WLC and then I want to just load a config file, or again is it a step by step process?
Regards!
The Solution has been added in the following Document:-
https://supportforums.cisco.com/docs/DOC-21757
Solved! Go to Solution.
01-05-2011 02:23 PM
Starting from 5.2 or later, when loading the config file via FTP or TFTP, you can actually open it with a text editor and it should show as a list of commands:
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60mfw.html#wp1046683
In this way you can make changes with the text editor and load it back to the WLC.
Alternatively, you could also copy the whole config as a text, go in the WLC's config mode (with the "config" command) and at the prompt "config>" simply copy the whole config text file.
Hope this helps,
Fede
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
01-05-2011 02:23 PM
Hope this helps,
Fede
09-22-2011 11:57 PM
but is there a method to save configs automatically and periodically ? (To TFTP/FTP server or anywhere? )
Using WLC 5508 , software version 7.0166
09-23-2011 12:10 AM
If u hv the WCS then u can do this!!
Surendra
09-23-2011 12:32 AM
Need to do this without WCS
09-23-2011 05:54 AM
yes, this is possible via expect
See my post https://supportforums.cisco.com/message/3438536#3438536
which explains how to do this exact task
05-15-2012 06:26 AM
Is there a doc out to show or explain how? Ive been searching for a few days and have found nothing on how to make that work
05-15-2012 06:33 AM
How to do this with WCS
12-09-2011 10:38 AM
Kiwi / Solarwinds makes a product called CatTools that does this and is free for up to 20 devices:
www.kiwisyslog.com/kiwi-cattools-overview/
It was a bit more difficult to configure to work with my WLC than switches, routers and PIX/ASAs but it works.
01-03-2012 12:27 AM
