151
Beginner
WLC License Transfer
regards
I have 2 controllers
The first has 15 licenses WLC CISCO 2504
The second i purchased has 12 licenses. WLC CISCO 5508
And i have 13 APs installed on my site.
I would not use the first controller due to device failure.
How can i move 15 APs license from the first [2504] controller to the second [5508]?
1 ACCEPTED SOLUTION
Highlighted
Rising star
Re: WLC License Transfer
If its due to one of the WLCs failing and there is a support agreement TAC can do it.
Normally they don't let you move licences between these controllers but you could request from licensing or via your Cisco AM/ SE
*****Help out other by using the rating system and marking answered questions as "Answered"*****
2 REPLIES 2
VIP Mentor
HI,
If the 2504 controller have the 15 AP as base license then it will really hard to get it transfer. But if these are installed as adder license then you can contact to cisco License team: licensing@cisco.com,  they should be able to answer your questions.
Dont forget to rate helpful posts
Highlighted
Rising star
Content for Community-Ad
August's Community Spotlight Awards
