WLC Makes Makes Loud Noise Time to Time
giridar
Have brand new WLC and it makes loud noise time to time,
software version:8.3.143
Fan RPM rates are normal
went to similar threads and a common fix was to change fan policy - performance
but unable to do so because it shows cisco fan policy override - card(s) cavium present
please advise
7 Replies 7
If your AP support 8.5.140.0 code I would upgrade to that & see.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
Rasika
thanks and we have AIR-AP2802I-E-K9, checked the download site
8.5.140 has been deferred
the recommended one is Release 8.5.151.0 but I do not find it on the matrix
Leo Laohoo
"brand new WLC"? What is the model?
it is a 5520
The 5520 is loud when it boots up, but not much loader when running normal. The fan does spin up here and there, but again, that is normal.
-Scott
Does the WLC sound like a Hoover vacuum cleaner?
If it does, then it's normal. The controller, after all, is a UCS server.
yes, it sounds like a Hoover vacuum cleaner
