02-15-2013 03:36 AM - edited 07-03-2021 11:32 PM
I have a WLC 2106 which is configured and working as follows:
Site A:
Network: 10.0.0.0/22
3 AP's configured
Radius authentication configured on local server
DHCP handed to clients via local server
Site B:
Network: 10.0.28.0/22
1 AP connected. I have created a new WLAN for this AP
My question is how do i get the AP at Site B to use the local server (10.0.28.x) to hand out DHCP leases?
02-15-2013 03:53 AM
You would need to configure the AP at site B to be in HREAP/FlexConnect mode.
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_flexconnect.html
02-15-2013 04:50 AM
Thanks for the reply.
Once i have changed the AP mode to HREAP, do i need to use the DHCP override option or create a new interface to point it to the DHCP server at Site B?
02-15-2013 05:34 AM
Once you change any APs from local to h-reap, you need to define the WLAN to vlan mapping. This is done by clicking on the ap and clicking again on the h-reap/FlexConnect tab. There you will set the nativ vlan and hit apply and go back to that page and click on vlan mapping. You need to set your WLAN to local switching also. All this is documented in the h-reap or FlexConnect deployment guide.
