01-21-2013 03:47 AM - edited 07-03-2021 11:23 PM
Hi all,
We are going to implement high availabilty in 5508 WLC with version of 7.3.101 . We will be using Prime infrastructure 1.2 for monitoring purpose.
With Prime , whether we can monitor and manage redundant WLC also or only active WLC?...
Thanks for your help.......
Solved! Go to Solution.
01-22-2013 01:29 AM
Can u please explain or give the link.....
01-22-2013 02:09 AM
I just know from experience. You can only GUI/ssh into the primary WLC when you enable AP-SSO. So once the pairs are in HA, that is it.... You have only the primary WLC IP address available. You learn things the hard way sometimes because there are things not documented.
01-21-2013 10:15 AM
No... the PI will only see the primary.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-22-2013 01:29 AM
01-22-2013 02:09 AM
