ā09-09-2016 07:37 AM - edited ā07-05-2021 05:48 AM
hi folks,
could you please help me with the subject? I saw somewhere such document which describes meaning of the each particular number like in IOS versioning but unfortunately can't find it.
thanks in advance!
ā09-09-2016 08:24 AM
Ruslan,
This might help or else look at the release notes:
https://supportforums.cisco.com/document/77131/understanding-access-point-os-images
-Scott
ā09-14-2016 07:16 AM
hi Scott,
sorry for late answer, was a little bit busy.
thanks, close but not that I was looking for.
maybe this information is destined for the partners or not really public, because as I remember there was such explanations: x.y.z.n and x.y - its major and minor version numbers and so on, z - if 100 it's initial release, if 120, than bug fixing, if 133 - it's future adding and so on (it's not exact meaning, I just wanted to give understanding).
something like that.
ā09-14-2016 07:26 AM
Pretty simple:
.110 MR1
.120 MR2
.130 MR3
if a code is for example .120.11, that means it's a escalation image and can vary depending on the fix for a customer.
-Scott
ā09-14-2016 07:35 AM
yes, very similair to what I'm looking for, where did you find this information:)?
and if I have 8.0.133.0 - what does this mean?
ā09-14-2016 07:40 AM
I use to work for CDW a Cisco Partner and this is what you learn:)
8.0.133.0
8 - Code train
0 - First version for the code train
133 - MR3 with an escalation fix
0 - Escalation version (none here) usually you get these when you open a tac case and they build a fix for you
The 133 basically means that 130 had issues and Cisco had to fix the code and published MR3 with fixes.
Hope that helps
-Scott
ā09-14-2016 08:09 AM
I thought so:)
so 121 - MR2 with escalation fix 2? 113 - MR1 and esc. fix 3? and MR number increasing means implementing new features?
ā09-14-2016 08:14 AM
Not really.. 13x x is what're version they decide on and only can be from 0-9. You can say 131 is the first bug fixes and 132 is the second, but it depends on when the code gets published. Escalation images are 133.x
-Scott
ā09-14-2016 08:45 AM
uhm, oh, cisco as usual, with those sophisticated concepts and unobvious meanings:).
which version is better for upgrade in regular cases?
