Highlighted
Beginner
WLC SSO on LAG Standby goes offline
Hi Guys
WLC 5520 x 2
on SSO
Configured and it's working
I'm using LAG on both the WLC's
the stand-by WLC port sometimes goes offline due to which the failover doesn't take place during this time.
as per the documentation from cisco we cannot set LAG active (LACP) mode for the ports any other solution for this. what might be the reason.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
You should look at a different code. Here is a link to recommended code versions.
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
-Scott
5 REPLIES 5
Highlighted
Hall of Fame Master
Can you elaborate on your question? You want to connect using LAG on the controller, but your switch doesn’t support ether channel mode on? Because PAgP and LACP is not supported on the AireOS controllers.
-Scott
Highlighted
VIP Advocate
Or do you mean that the Standby WLC is crashing?
If yes, what software version are you running?
Highlighted
really sorry for the long delay
yet it seems to be crashing
we are currently having 8.3.1 on WLC 5520
Highlighted
Hall of Fame Master
-Scott
Highlighted
Upgrade to 8.5.161.0 worked
Content for Community-Ad
