05-28-2018 06:02 AM - edited 07-05-2021 08:40 AM
05-28-2018 09:09 AM
Looks like a Problem with Chrome security.
I have done some searches...
Maybe it is due to HSTS.
If you connect to your wireless SSID you have to open your brower and open a URL.
So could you try to open an unencrypted URL ?
05-29-2018 04:51 AM
Have any solution with ssl.
05-29-2018 04:52 AM
Install an SSL cert for web auth.
10-08-2018 08:13 AM
May i know any solution for this issue because i'm having the same as well, if possible to create a self signed cert on WLC will solve this issue at android google chrome browser?
