04-28-2018 12:48 AM - edited 07-05-2021 08:34 AM
HI,
I have two wireless controller,one WLC version is 7.0.116.0,another one version is 7.2.110.0.I want to upgrade WLC5508 from 7.0.116.0 and 7.2.110.0 to 8.3.130 .So,could you tell me whether there are some Precautions?Thanks.
Solved! Go to Solution.
04-30-2018 08:20 AM
04-28-2018 12:58 AM
Read the Release Notes.
And why pick 8.3.130.0?
04-28-2018 01:05 AM
04-28-2018 06:32 AM
What Leo is suggesting is to take a look at the release notes and then the open caveats that is listed. Review that piece so that you know what issues there are on that release. It’s also a good idea to point out risk to the customer especially if you are a consultant. If a customer request a certain code, then at least call out the risk so that you are covered.
04-28-2018 06:43 AM
04-28-2018 06:47 AM
@Rps-Cheers wrote:
But,I still want to know the need about upgrading 7.0 and 7.2 to 8.3.130.0.
Ask the client if they know about KRACK.
04-28-2018 06:59 AM
04-30-2018 02:40 AM
I would definitely avoid 8.3.130 if you can. We are running that since February when KRACK was patched but having so many issues with it. APs drop and crash as well as roaming issues.
Cisco told us to go on 8.5.120 so we are doing that next weekend.
Previously we were on (a long time ago) 7.4 then jumped on 7.6.130 and then to 8.0.121. From there you can go to any version. If you are running 7.0 though, you must have some old APs, you might not be able to go on 8.3.130 and above if you have legacy APs. Otherwise, code 8.2.166 is very stable too.
Cisco now recommends s 8.0.152 all of a sudden.
Serge.
04-30-2018 02:53 AM
8.5.130.0 coming out in the next 24 hours.
04-30-2018 03:04 AM
Thanks Leo. I guess that supersedes the 8.5.120? Did you try it at all?
04-30-2018 03:06 AM
I didn't try 8.5.120.0 because I'm holding out for 8.5.130.0.
04-30-2018 03:09 AM
Cool, we have been testing 8.5.120 for a month now. Very stable. Used with APs 3600, 3700 and 3800.
04-30-2018 07:45 AM
04-30-2018 07:56 AM
Thanks. Will test it before Saturday.
04-30-2018 08:02 AM
