Identifier | Headline |
CSCva50180 | AIR-CAP1602I-E-K9 stopped working |
CSCuy29182 | Peer Upload:No progress status, no error, normal Upload error misleading |
CSCuz97296 | AP3500: Client Pak stuck during Payload Encryption |
CSCva27419 | Channel changed trap with Unknown Radio Type on dual band radio |
CSCva59172 | RF - Profile paramaters are not pushed for optimised roam |
CSCva87833 | AIR-CT8510-K9 crashed |
CSCvb14702 | client couldn't join if it sends two assoc at the same time |
CSCvb57793 | AP does not fragment EAP cert correctly |
CSCvb71347 | WLC multicast config not coherent for code upload/download |
CSCvb86237 | Cisco 8510 WLC stopped working Task Name: TempStatus |
CSCvb89967 | Rogue reports don't have source mac address populated |
CSCvb90235 | Cisco3700 WGB inconsistently facing joining issues because of no probe response by 3600-11ac root AP |
CSCvc07674 | WLC sends ciscoLwappApAssociated trap twice when AP2800 join |
CSCvc17678 | 83MR1: wrong "enable global mDNS snooping" message when clinking apply on barbados edit |
CSCvc18786 | WLC stops working during multiple login sessions either with local user or with TACACS+ |
CSCvc19987 | Fresh WLANs not getting broadcast in AP3802 |
CSCvc24104 | Rx-SOP threshold failed to set with AP model 1852/1700/1815/1830 |
CSCvc24917 | Defect of msglog corresponding to 'AP Message Timeout: Max retransmissions reached on AP ...' |
CSCvc28035 | clDLApBootTable shows blank when WLC has 2800I AP |
CSCvc35183 | CISCO-LWAPP-CLOUD-SERVICES-MIB: Parse errors like bad month and undefined objects |
CSCvc37641 | AP 700 doesn't provide SSH access in wips submode for flexconnect |
CSCvc51637 | 802.1x CCKM roams fail on WGB at GTK key rotation |
CSCvc51666 | Cisco Wave 1 AP transmits on disabled rate 24Mb |
CSCvc55430 | WLC HA redundancy management interface not reachable for a short time after failover |
CSCvc56757 | WGB HSR 11v neighbor report validation fails when Infrastructure MFP is enabled |
CSCvc61795 | IP call setup fail after L3 handover happens during call among 1832 |
CSCvc67705 | 1815 : Flex efficient predownload failed |
CSCvc71537 | WLC profiles 7925 incorrectly |
CSCvc72724 | 8510 AP SSO stopped working on portalProcessLogout |
CSCvc84637 | 1810W sending invalid AC_NAME when WLC hostname is 31 bytes long |
CSCvc85158 | AP Group configs not retaining during upload and dowlnoad config. |
CSCvc90036 | Unable to convert CAPWAP AP to Mobility Express |
CSCvc93377 | Tracebacks and MFP queue logs filling up the msglog on WLC. |
CSCvc94704 | WLC crash due to task dtlArpTask |
CSCvc96076 | Cisco WiSM2 HA - standby stopped working with task name spamApTask2 in ideal state |
CSCvd09507 | Rogue rule substring-ssid turns invalid on WLC when user configured SSID is included in PI template |
CSCuc78713 | dWEP client cannot receive broadcast after broadcast key rotation |
CSCuy75333 | Cisco 2504 WLC config restoration fails due to multicast mode command |
CSCuz59858 | AP 3500(SC1), client association failure - R2H Buffer full |
CSCvd16346 | WLC memory corruption occurs when TACACS+ responds with unknown attributes |
CSCvd23185 | WGB wired clients not seen by WLC |
CSCvd23301 | WLC GUI trapflags for client association with statistics does not display correct configuration |
CSCvd23902 | Cisco 1532AP: root bridge drops packets from non-root bridge in non-native VLAN |
CSCvd26885 | Unit of probe suppression hysteresis should be 'dB' |
CSCvd28374 | Cisco 802AP incorrect base radio MAC assigned not ending with zero results in only one BSSID support |
CSCvd30486 | 2800/3800 - Radio incorrectly shown as disabled due to PoE |
CSCvd31705 | AP: Offchannel cleanup in IRQ context can trigger an indefinite loop if sensorD owns the radio |
CSCvd35885 | ME2800 Crashes with Task Name : capwapSocketTask |
CSCvd36190 | Cisco 5520 WLC stopped working with taskname haSSOServiceTask6 |
CSCvd37522 | show run-config commands: incorrect index numbers for RADIUS Accounting Servers |
CSCvd42669 | Cisco 2500 WLC stopped working |
CSCvd44909 | Client traffic dropped in Anchor foreign AirOS setup with new-mobility if foreign client behind NAT |
CSCvd45744 | Customer reports that AP reboots after 4 hours while doing site survey |
CSCvd56588 | In 2800 and 3800 series APs, incorrect RSSI values are displayed when client associates to XOR radio |
CSCvd61468 | Custom mDNS profile is not saved on the WLAN config after the reboot |
CSCvd62184 | AP3600: Radio reset /w reason reqsema on 8.3MR2 |
CSCvd62568 | XML validation is failing for the AVC profile |
CSCvd67730 | Client fails PSK SSID authentication after master AP reboot (EAPOL M3 not sent on 4-way handshake) |
CSCvd68141 | WLC stopped working at task nmspRxServerTask |
CSCvd72131 | Cisco 7500 WLC in flex-mode stopped working after the SNMPTask Reaper reset |
CSCvd74297 | AP3800/2800: Extended core dump CLI is not persistent |
CSCvd79511 | Radius Admin mode goes for Disable state in LTB setup |
CSCvd80240 | FlexConnect AP sends associate response with wrong HT capabilities |
CSCvd80508 | LAN ports of the 1810W AP are stuck on Admin-Down after modifying RLAN settings |
CSCvd86566 | Client with incorrect NAI realm gets Access-Accept from Radius Server |
CSCvd90377 | WLC is applying wrong ACL to clients when doing CWA |
CSCve02210 | SNMP OID that is used to monitor WLAN status for FT is returning wrong results |
CSCve02585 | Webauth login page is not showing up after enabling TLS1.2 on WLC |
CSCve02612 | HA-Config sync fails on standby when flex AP configs are modified |
CSCve02689 | Silent reboot is observed after the memory usage goes up to 85% |
CSCve05507 | Retransmit configuration is not reflected when new 1800, 2800, and 3800 series APs join the WLC |
CSCve13779 | AP2802 Rogue Detection config changed back to "Enabled" after AP reboot |
CSCve20123 | Corrupt voice packets are observed when a client with an active call does an inter-AP roam |
CSCve20825 | 8.5 rf-group member ip address updated as reverse in config |
CSCve22001 | ME Default value of Wlan param is cahnged after config restored |
CSCve24687 | Channelization issue occurs when Cisco 3802 AP reverts to channel 36 for 75% of APs at a site |
CSCve27826 | WLC-8510 - Transfer failed on both active/standby |
CSCve33506 | Client EAP-TLS handshake does not succeed with the Cisco 1830 AP |
CSCve35431 | Downstream QoS 802.11 UP marking does not work for Flex AVC profile |
CSCve37579 | Cisco 3800 AP stops working due to WIPS kernel panic |
CSCve37770 | Cisco 5508 WLC stops working when AP's radio CLI command is executed |
CSCve45744 | Cisco 1850 AP stops working due to memory leak in slab SUnreclaim |
CSCve49741 | Cisco WLC fails to send SFTP and FTP when using untagged interfaces on different ports |
CSCve52807 | crash standby WISM with task name 'rsyncmgrIpcqTask' on 8.5.1.146 |
CSCve61049 | Radio resets in Cisco 2700 AP |
CSCve63497 | Cisco WLC stops working with Task Name emWeb when timer changes |
CSCve63755 | Cisco WLC running 8.4.100.0: Cisco APs fail to join the WLC if it has LSC enabled on it |
CSCve63800 | Prime Infrastructure does not show all WLANs when querying MIB bsnAPGroupsVlanMappingSsid |
CSCve66007 | Cisco 8540 WLC stops working with Task Name emWeb |
CSCve66630 | Clients cannot connect to Cisco 3800 AP when configuring TKIP only WLAN and PSK with central auth |
CSCve68787 | Cisco AP is not transmitting out the de-auth frame over the air that was received from the WLC |
CSCve75022 | Cisco WLC does not apply QoS tag upstream from foreign to anchor |
CSCve76202 | WLC IPv4 CPU ACL is applied as IPv6 CPU ACL during backup recovery or SSO failover |
CSCve80178 | AP 3800/2800: 8.2.154.42 TPC implement not advertising same WLANs (different AP Group) |
CSCve83915 | 32 chars match role string is not accepting in cli unlike gui |
CSCve86609 | Dynamic interface default gateway must not be configured to "0.0.0.0" in CLI |
CSCve89758 | vWLC code download fails with HTTP mode |
CSCve90085 | Active WLC in HA pair crashes with task apfRogueTask_0 |
CSCve96310 | Cisco WLC installs certificate without a password. However, WebAuthentication fails. |
CSCve96480 | IOS AP stopped working when it is changed from sensor mode. |
CSCve98892 | DNS lookup for RADIUS/TACACS fails because it is queried before the physical port is up |
CSCvf03782 | WLC stopped working on emWeb with "ewaFormSubmit_file_upload" in stack |
CSCvf05046 | 1800/2800/3800 AP Correction in unit of antenna gain in show controller output |
CSCvf09441 | pmipv6 MAG is not initialized in the backend |
CSCvf09458 | Cisco 2800/3800 series XOR radios are not moving to 5GHz or Monitor mode |
CSCvf15991 | Client data traffic drops when AAA override and link-local-bridging are enabled due to timing issue |
CSCvf16629 | The OUI string updates properly in Cisco 5508 WLC but disappears after a reboot |
CSCvf17488 | WLC crash with task name: mmMaListen on 8.4.100.0 |
CSCvf31894 | Backout changes - CSCvc78546 that leads to CSCve20123 |
CSCvf33081 | WLC running 8.3.121.0 is not accepting IPs for NetFlow exporter when ending between .223 - .255 |
