Can Cisco AIR-CAP1602I-ZK9 Access Point work without Controller?
1723
Naderi
Beginner
Hey Guys,
I Have several 1600 Series AP's (AIR-CAP1602I-ZK9) that was working with WLC before, I changed them with 1800 series but would like to use 1600 Access Points series independently and without WLC for somewhere else,  so I want to know do they work without the Wireless LAN Controller? or I have to have the controller for them to work? they will be in different locations so i cant have a controller per each location and if yes how can I convert them to Mobility Express or a Mood that I can use them as a simple Access point.
9 Comments
Leo Laohoo
VIP Community Legend
If the 1600 is loaded with Autonomous IOS then the AP can/will work without the need for a WLC.
NOTE:  1600 do not support Mobility Express.
Naderi
Beginner
Thanks @Leo Laohoo ,
Sorry, I tried to loaded with Autonomous IOS but I got some error to BOOT it, so should I use this IOS :
https://software.cisco.com/download/home/284366503/type/284180979/release/15.3.3-JF12i
I tried to change it via TFTP.
Leo Laohoo
I have already responded to the other thread (LINK) with a solution.
Naderi
Beginner
Yes Thanks I saw it, because I have several 1600 Series AP's and need to loaded all of them with Autonomous IOS.
I will try again and I hope to solve it soon,
Thanks for your help
Naderi
Beginner
Hi Leo,
Thanks for your help, I loaded with Autonomous IOS all is ok but when I login on web gui and try save or apply anything I get error 404 not found!
is it because of software version issue? I'm using : ap1g2-k9w7-tar.153-3.JF12i
Leo Laohoo
Post the complete output to the command "sh version".
Naderi
Beginner
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.3(3)JF12i, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 16-Apr-20 00:52 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
ap uptime is 45 minutes
System image file is "flash:/ap1g2-k9w7-mx.153-3.JF12i/ap1g2-k9w7-xx.153-3.JF12i"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1602I-Z-K9 (PowerPC) processor (revision B0) with 187386K/74672K bytes of memory.
Processor board ID FGL1910X8QN
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A8:9D:21:03:2C:DC
Part Number                          : 73-14671-04
PCB Serial Number                    : FOC19075PJ9
Top Assembly Part Number             : 800-38552-03
Top Assembly Serial Number           : FGL1910X8QN
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-Z-K9
Configuration register is 0xF
Leo Laohoo
Ok, so the AP is loaded with Autonomous IOS.
What happens if you try to save the config using CLI?
Naderi
Beginner
CLI is ok just when I trying save or apply anything on web gui I get error 404 not found!
Create
Recognize Your Peers
Content for Community-Ad
