Michael Durham
Level 4
Level 4
I have a few AIR-CAP3502E-A-K9 access points that I want to change to Lightweight mode.  I did a lot of researching and found that I needed the ap3g1-k9w7-tar.153-3.JAB.tar file or a similar version of it.
I do have that file and I was able to upload it to the 3502E and it does boot up. But, neither radio will come up.
*Mar 1 00:35:37.228: Interface Dot11Radio0: not starting because stop-on-failure set
StreetWalker(config-if)#
*Mar 1 00:35:37.231: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
The radio status shows up but the protocol says down.
I tftp'd the IOS to the AP and then ran the archive command then deleted all of the CAP type files.
Any ideas on how I can get this working correctly?
2 Comments
Leo Laohoo
Post the complete output to the command "dir".
Michael Durham
Level 4
Level 4
2 -rwx 104609 Feb 28 2002 19:10:54 -05:00 event.r0
3 -rwx 8277 Feb 28 2002 19:37:45 -05:00 config.txt
4 drwx 192 Feb 28 1993 19:17:25 -05:00 ap3g1-k9w7-tar.153-3.JAB
5 -rwx 10250240 Feb 28 1993 19:11:36 -05:00 ap3g1-k9w7-tar.153-3.JAB.tar
219 -rwx 392 Feb 28 2002 19:23:58 -05:00 env_vars
6 -rwx 80984 Feb 28 1993 19:17:49 -05:00 event.log
220 -rwx 104582 Feb 28 2002 19:11:02 -05:00 event.r1
221 -rwx 168 Feb 28 2002 19:11:02 -05:00 r0.rcore
222 -rwx 239 Feb 28 2002 19:11:14 -05:00 r0.rcore.info
223 -rwx 168 Feb 28 2002 19:11:14 -05:00 r1.rcore
224 -rwx 239 Feb 28 2002 19:11:26 -05:00 r1.rcore.info
225 -rwx 1916 Feb 28 2002 19:37:45 -05:00 private-config
226 -rwx 2072 Feb 28 2002 19:37:45 -05:00 private-multiple-fs
French webcast-routing
