surenkanna4848
Hi All,
Currently i have a 9800-cl wlc with 2700, 3800 and 9100 series access points (internal APs).
All three APs broadcast same SSID with (WPA2/PSK) for come legacy clients which operates on 802.11b.
Also I'm using the same RF, site and policy Tags across all three Access points.
Issue: The legacy clients only connect with 2700 series AP via the above SSID on 802.11b radio, not with 3800 or 9100.
Anyone come across with similar issues before?
Please advise.
Suren
2 Comments
Scott Fella
I have only client device that is 802.11bg but requires 802.11b data rates or else it will not connect. I have 3702, 4802, 9120 and 9130’s with 9800-L and have no issue with the device connecting. Now your device might just be very old which I do not have. These were also working on 5520’s prior to moving them to the 9800’s.
surenkanna4848
Hi Scott,
Thanks for the reply.
May I know, what is the software version you are running on 9800-L ?
French webcast-routing
