Community Helping Community
Cisco Cius Overview and WLAN Configuration
1754
Rising star
Robert Tracy is a Wireless Expert working in Cisco TAC for 7 years. This video provides configuration options to configure Cisco Cius with the wireless local area network (WLAN).
Overview of Cisco Cius:
Cisco Cius is a mobile collaboration device for business. Cisco Cius provides an integrated suite of collaborative applications, including Cisco Quad, Cisco WebEx, Cisco Unified Presence, instant messaging, email, visual voice mail, and Cisco Unified Communications Manager voice and video telephony features. Cisco Cius also provides Virtual Desktop Infrastructure (VDI) and cloud computing and support for a wide range of applications through Cisco AppHQ Developer Network Marketplace. Cisco Cius also supports applications from the Google Android Marketplace. For an overview of the features that Cisco Cius supports and for tips on configuring them, see Configuring Features, Templates, Services, and Users.
As with other network devices, you must configure Cisco Cius to prepare to access Cisco Unified Communications Manager and the rest of the IP network. By using DHCP, you have fewer settings to configure on Cisco Cius, but if your network requires it, you can manually configure an IP address, TFTP server, netmask information, and so on. For instructions on configuring the network settings on Cisco Cius, see the Setup Menus on Cisco Cius.
Finally, because Cisco Cius is a network device, you can obtain detailed status information from it directly. This information can assist you with troubleshooting problems that users might encounter when using their Cisco Cius devices. See Viewing Model Information Status and Statistics on Cisco Cius for more information.
Cisco Cius includes the following features:
•Campus mobility with a choice of wired Gigabit Ethernet connectivity through handset media station or IEEE 802.11 a/b/g/n Wi-Fi connectivity
•An Intel Atom 1.6-GHz processor
•1-GB RAM and 32-GB of eMMC flash memory
•Native support for Bluetooth headsets
•Bluetooth profile support, including Hands-Free Profile and Advanced Audio Distribution (A2DP) Profile
•High-definition video through 7-inch (177.8 mm) high-resolution color screen.
•High-definition audio through integrated speakers
•Microphone
•Front- and rear-facing cameras
•Detachable and serviceable 8-hour battery
For more details on Wi-Fi Settings Menu:
Option
Description
To Select or Change
Wi-Fi settings
Wi-Fi
Enables or disables Wi-Fi.
Tap to enable or disable Wi-Fi connection.
Network Identification
Notifies the user when an open network is available.
Tap to enable or disable notification.
Neighbor List
Displays current Wi-Fi connection.
Tap to display current Wi-Fi connection.
Wi-Fi networks
List of WI-Fi networks
Displays Wi-Fi networks.
Tap network to access.
Add Wi-Fi network
Adds Wi-Fi network.
To add a network, select from broacasted/available WLANs or select Add Wi-Fi network to manually add network.Note For broadcasted/available networks, enter Password, if applicable, and select Frequency band. For new networks, enter Network SSID, Security, and Frequency band.
Network SSID
Specifies the Service Set Identifier (SSID), a unique identifier for accessing wireless access points.
1. Tap and hold Wi-Fi network to change.
2. Select Modify network.
3. Enter SSID.
4. Tap Save.
Security
The type of authentication that Cisco Cius uses to access the WLAN. Valid values:
Open
WEP
WPA/WPA2 PSK
802.1x EAP
Note Supported 802.1x EAP methods are PEAP and EAP-FAST. Server validation for PEAP is not supported.
1. Choose Wi-Fi settings > Add Wi-Fi Network.
2. Select Security.
3. Select Security option.
4. Tap Save.
The Wifi parameter is left at the default value (enabled) but without the "Override Common Settings" check box checked.
For a detailed explanation of wireless security, see the Cisco Cius Wireless LAN Deployment Guide
Cisco Cius Administration Guide, Release 9.2(2)
Do Rate the Video.
Content for Community-Ad
August's Community Spotlight Awards
