What version of PI do you recommend for small scale network with 2*9800 Catalysts, 2*5520 and 3*5508 controllers and with a mix of 350+ APs. (including 9Ks)
You should open a TAC case if you have to restart PI every so often. If it’s a VM, make sure your hardware meets the requirements especially with IOPs.
