atsetheodros
Level 4
Level 4
What version of PI do you recommend for small scale network with 2*9800 Catalysts, 2*5520 and 3*5508 controllers and with a mix of 350+ APs. (including 9Ks)
7 Comments
Leo Laohoo
PI 3.8
Scott Fella
Leo… they removed 3.8 so 3.7 is the only one available for public download.
Scott Fella
Go with PI 3.7 since all the 9800’s are supported on that platform.
shadom
Level 5
Level 5
I have PI3.7 with same platforms - Although PI3.7 does need a reload from time to time...
Scott Fella
You should open a TAC case if you have to restart PI every so often. If it’s a VM, make sure your hardware meets the requirements especially with IOPs.
atsetheodros
Level 4
Level 4
Since I got the PI3.7 mine works smooth
Leo Laohoo
French webcast-routing
