Cisco Prime Infrastructure
530
Enthusiast
What version of PI do you recommend for small scale network with 2*9800 Catalysts, 2*5520 and 3*5508 controllers and with a mix of 350+ APs. (including 9Ks)
7 Comments
Hall of Fame Community Legend
PI 3.8
Hall of Fame Master
Leo… they removed 3.8 so 3.7 is the only one available for public download.
Hall of Fame Master
Go with PI 3.7 since all the 9800’s are supported on that platform.
Contributor
I have PI3.7 with same platforms - Although PI3.7 does need a reload from time to time...
Hall of Fame Master
You should open a TAC case if you have to restart PI every so often. If it’s a VM, make sure your hardware meets the requirements especially with IOPs.
Enthusiast
Since I got the PI3.7 mine works smooth
Content for Community-Ad
Cisco COVID-19 Survey
